moisture in tail light
Old Jun 9, 2004 | 10:34 PM
charged99's Avatar
Arrow moisture in tail light
well im getting moisture in my passenger side tail light. They are aftermarket all black ones so Im not surprised. Does anyone have any suggestions. I was thinking of drilling a small hole, but where on the light will be most effective and no noticeable.
Old Jun 10, 2004 | 06:58 AM
ARTIE54's Avatar
Don't feel bad my driverside factory does the same thing! I'm going to pull it out and drill a 1/16" dia. hole in the bottom. to see if that fixes it! Artie
Old Jun 10, 2004 | 10:10 AM
LIGHTNINROD's Avatar
My 01 L's right tail light got moisture in it a year or so ago. All I did was drill(Unibit drill--one of the greatest-ever inventions) two small(?) holes in the cover; one near the front/side and one in the rear so air would flow through. No need to remove anything. Worked like a 'charm'.
Dan
Old Jun 10, 2004 | 11:04 AM
Tim Skelton's Avatar
I don't think that the location makes any difference, nor the size.
So, to keep out bugs and not invite water collection, why not the smallest bit you have drilled right at the very bottom of the rear surface? That way, any water that gets in the hole can drain right out.
Old Jun 10, 2004 | 11:06 AM
Originally posted by LIGHTNINROD
. . . Unibit drill--one of the greatest-ever inventions. . .
AMEN, Brother! I have three different sizes. Not only are they soooo convenient, but they also just never seem to dull or wear out.
I have used them to drill out holes in the frame. Went through like a hot knife through butter.
Old Jun 10, 2004 | 11:20 AM
charged99's Avatar
yeah im gonna drill a small hole in the bottom of the tail light.
hopefully you wont be able to notice it too much.
