Engine Noise?
Old Jun 8, 2004 | 08:56 PM
BLk01L's Avatar
Engine Noise?/ now engine light also!
I have a fluttering sound coming from the engine only when i step on the gas even a half throttle, it sound kinda like a fan, It's not the blower whine. Any Ideas on what this might be?
Old Jun 8, 2004 | 09:10 PM
Suavy's Avatar
Does it kind of sound like a bogg?
I know you said fluttering...
You might think about checking your plugs. Reason being, 3 weeks ago I got on my truck late at night like about 3:3am it was 42 degrees here in the great white north! I got on it went to wide open throttle and heard clattering (detonation) I got out of it like right now! Tried to get on it again from a dead stop and heard a fluttering sound. Maybe, bogging sound. Went home pulled my plugs shure as chit! I toasted the #8 plug.
Suavy
Old Jun 9, 2004 | 02:40 PM
BLk01L's Avatar
any other ideas?
Old Jun 9, 2004 | 02:45 PM
AmoJohnny's Avatar
detonation?
wydopnthrtl's Avatar
Number 1 thing is to check plugs. Not only to see if they are loose or badly deteriorated. But to read what your tune is. (killing 2 birds with one stone)
If that's ok, then I'd get a mechanics steth-o-scope and start trying to isolate where the noise is coming from.
Is it directly related to rpms? Or related only to load?
Rich
Old Jun 9, 2004 | 04:49 PM
TiresWinRaces's Avatar
Check the plugs for sure, but it could also be an exhast leak. It sounds like a soft flutter that gets louder with increased load.
My stock exhaust had a slight one. If you've ever loosened the collector bolts, that's probably it. Mine got worse after the catback install. I've got it under control now and it's livable. Just have to do some adjusting on the pipe angle.
Old Jun 9, 2004 | 08:58 PM
BLk01L's Avatar
i will check the plugs asap, i just took the L for a drive and the noise almost sounds like it is comming from underneath the engine, when it is in park and i rev the engine there is no noise, i had the plugs change when i got the chip and pulley at REM about a month and a half ago
Old Jun 10, 2004 | 05:19 PM
BLk01L's Avatar
any idea why i would not here the noise if i am in park and reving the engine
Old Jun 10, 2004 | 08:18 PM
SVT F15O's Avatar
Fan clutch>??? -Mat-
Old Jun 10, 2004 | 09:20 PM
BLk01L's Avatar
Its going to the dealer tomorrow because the engine light just came on!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !
Old Jun 10, 2004 | 10:29 PM
JeffsLightning's Avatar
If it's still under warranty look for a denial....Good luck
Old Jun 11, 2004 | 06:43 AM
ARTIE54's Avatar
Pull the chip and pulley!!!!!! Before you go and disconnect the battery for a while !! Artie
Old Jun 11, 2004 | 07:21 AM
BLk01L's Avatar
its not under warranty, so im not worried about the chip or pulley, i actually have a warrany through an indepentent co, in case the engine blows
Old Jun 11, 2004 | 08:48 PM
BLk01L's Avatar
Dropped the car off at the dealer and told the service rep i had a chip and pulley( no warranty left) and he said "its a lightning why would you put a chip in it? I asked him to show me a L without a chip and pulley
