truck will not start first crank
my 03 is in for the same problem!!!! it that check valve on the fuel pump (but its one piece) so u have to replace the fuel pump!!! its not keeping it pressurized and u are getting air bubbles in the system!!!! its my second fuel pump @ 8000km
There are aftermarket, high flow units out there, probably cost less than OE.
Another possibility, if $$ is a problem, would be to post a WTB for a pair of OE "take-offs" either here on the NLOC or the NHTOC.
Good Luck.
Good Luck.
I think I may have the same problem with my 1999 Expedition 5.4L. Frequently when I get in the vehicle and turn the key over the SUV will not start. The ignition seems fine but it just does not fire. If I wait for a few minutes it usually works fine. I even turn the key on for a few seconds and it does not seem to help. Since this is intermitent I hate to take it in to hear "can;t find the problem, that will be $$$". I installed a new battery but that did not help either. I am thinking I do not get spark or fuel. Is there a test I can do to determine which is the culprit? This is definitly inconvenient and frequently embarrassing so i am anxious to get resolved.
