New mod...
Old May 20, 2004 | 05:53 AM
ARTIE54's Avatar
Hey Jeff you might want to change the GALVANIZED fitting for a brass one. with the aluminum and different metals you will get whats called galvanic action in that fitting. Which will cause rust and carrosion even in a closed system. Great job gonna try it myself. Artie
Old May 20, 2004 | 10:15 AM
JeffsLightning's Avatar
Good advice Artie...
Old May 20, 2004 | 12:25 PM
D Davis's Avatar
Jeff , Artie , Thanks a bunch for the Info.
thinking I'll get sensor and display from salvage yard and mount somewhere so I can have both
Old May 20, 2004 | 07:15 PM
RollinLimp2001's Avatar
So what is the refresh rate on the sensor like hooked up to the I/C? I know as the outside temp sensor if you would pull out of a cool garage and drive around outside where it's hot the gauge won't increment by 1 but will actually jump several degrees over a certain time period...like between 5-10 seconds refresh. Just wondering since it kinda has a more fluctuating environment now if it acted differently? Thanks.
Old May 21, 2004 | 03:28 AM
Made a slight change. Still should get a brass tee but this is the look for now...
Old May 21, 2004 | 04:40 AM
Rob_02Lightning's Avatar
Very cool Jeff
What temp reading have you seen so far ?
