does size matter?
Old May 8, 2004 | 04:54 PM
lightninquick's Avatar
does size matter?
i know its the age old question. however i would like to hear it straight from the horses mouth. the question refers to headers long or short. i just got a magnum blower from jdm along with the new sct tuner. installed on the tuner is two programs. 1st program is for the street and 91 octane. the 2nd program is for 100 octane. i was instructed by the guys at jdm not to run the second program unless i put on some headers and bigger injectors. there is some other part changes also, that i will not disclose. i just installed the magnaflow system but left the stock manifolds. jdm says the shorty's should be fine.
if anybody out there has the shortys lets hear about it. or if anybody out there knows somebody with the shortys ring in.
and p/s tim skelton i already did a search
Old May 8, 2004 | 05:41 PM
Blown5Pnt4's Avatar
I'm actually interested in this as well do to the fact of being offered a good deal on a set of JBA shorties.
Josh
Old May 8, 2004 | 06:37 PM
Tim Skelton's Avatar
Re: does size matter?
Originally posted by lightninquick
. . . and p/s tim skelton i already did a search
I'm not sure what kind of search you did, but I found the answer in 120 seconds. They suck. They produce no power gains. And the JBAs are hard to install and poor quality.
search
Old May 8, 2004 | 07:50 PM
airtroop01's Avatar
The problem with running long tubes is the issues come smog inspection time. Sure, everyone's gonna say use long tubes... and if I had my way, I would. However, I personally don't want to bother with pulling them off every 2 years. So, certainly there has to be a shorty header solution that should work better. I can handle the fact that instead of 25 hp (or whatever number) that I get 15. There isn't another header maker right now making CARB legal headers except JBA. Also, regarding poor quality. The stockers are built solid, but don't look like they'd flow even 1/4 of the exhaust that a JBA header would. In the late-model Mustang world, many have also said to not waste time with a shorty header. However, I have dynoed my mustang back to back with a shorty header and gained 15 rwhp with no other mods being done to it. Granted, the Lightning has a different engine... though I'm not yet convinced that the headers are crap.
Tim (not flaming here)- you normally have some pic or something to back up your convictions... I've seen JBA's dyno on their webpage showing a positive gain (could be only marketing hype I agree)... so do you have proof to say that they are crap?
Old May 8, 2004 | 07:52 PM
airtroop01's Avatar
addenum
my line of thought...
if the build quality is crap... which I can understand...
there could be a way to fix it????
addl. welding or something??
Old May 8, 2004 | 08:17 PM
RDSVT's Avatar
I don't know about the lightnings, but with the LS1 cars, and a lot of others short tube headers are a waste of time, effort and most importantly money. The only good thing about them is the work well in really confined spaces.
Old May 8, 2004 | 08:58 PM
Originally posted by airtroop01
. . . Tim (not flaming here)- you normally have some pic or something to back up your convictions... I've seen JBA's dyno on their webpage showing a positive gain (could be only marketing hype I agree)... so do you have proof to say that they are crap?
Just the information revealed by the linked search. Having reviewed the data, the conclusions were inescapable.
Old May 8, 2004 | 09:44 PM
mr2x75's Avatar
Tim your the man, I always get a kick out of your post lol.. straight to point no hype no bull...
Dale
Old May 8, 2004 | 11:44 PM
Unoid's Avatar
Re: Re: does size matter?
search
my JBA's seem of good quality? and I paid someone to install them...
Old May 9, 2004 | 11:46 AM
airtroop01's Avatar
any before/after dyno results Unoid?
Old May 9, 2004 | 12:55 PM
Redlightn 02's Avatar
Shorty's = low end torque
Long tubes = torque on mid to top end
Old May 9, 2004 | 04:47 PM
TriPodRacing's Avatar
airtroop01...Whay would you have to change your headers out for emisions test ? If you have cats on the truck it should be fine and you can get a program to limp to inspection,pass,go home put your reg. tune back in and you good to go.
Old May 9, 2004 | 05:12 PM
Unoid's Avatar
I've never dyno'd as of yet, sorry.
