The Glassing has begun
Old Apr 20, 2004 | 10:26 AM
  #46
TampaBlack99's Avatar
that hurts
Old Apr 20, 2004 | 10:34 AM
  #47
Konig's Avatar
Its ok man, its an addiction after all.
Steve: "Once you start....It's like crack....."
MPA - Metal Polishers Anonymous can help
Old Jun 15, 2004 | 05:44 PM
  #48
UPDATE
The glassing ontop of the dash did'nt work to well. The piece kept warping and would never lay flat. I used 2 different types of fiberglass resin and both warped on me. I am off to approach the project from another angle. I plan on removing the oval cover and laying the fiberglass inside the hole to form the base of the gauge cluster. I think this will work better and create alot less sanding as I will no longer have to worry about a perfect fitting base. It will also allow me alot more space for designing the cover and installing the gauges at the correct angle.
Time to spend another $30 on fiberglass resin and mat!
Old Jun 16, 2004 | 12:24 PM
  #49
Krix330cic(NJ)'s Avatar
shape your model out of foam.. get it the same "oval" shape on bottom, then glass mat over it.
Old Jun 16, 2004 | 12:41 PM
  #50
JimJr's Avatar
exactly what he said
