When do you guys change your Fuel Filter?
Old Mar 26, 2004 | 10:10 AM
georgia-SVT's Avatar
Do you guys change once a year or do you change it ever so many miles just wondering.I changed mine last year with 15,000miles it now has 26,000miles and I'm waiting on my custom tune from James @ RWTD what do you guy suggest.
Jeff
Old Mar 26, 2004 | 10:17 AM
Certified Drunk's Avatar
I change mine about every 6K miles. $10 and 10 minutes to change.
Old Mar 26, 2004 | 10:48 AM
wydopnthrtl's Avatar
Since I don't drive much anymore. Just once a year.
BTW: The navigator filter is about twice the size.
Rich
Old Mar 26, 2004 | 10:49 AM
fractaldragon's Avatar
Every other oil change. Of course I have only had one oil change thusfar lol. So my next one will be the fuel filter too...
Old Mar 26, 2004 | 10:52 AM
wkuper11's Avatar
I used to change mine every other oil change, but after spilling gas in my eye one to many times I started cutting the filter open to see if it actually was getting dirty, or clogged. I cut open two and they both looked brand new, no signs of debris or dirt. I guess it depends on where you live and where you get gas, I usually get gas at the same station and it seems to be clean so I'm going to change it every 6 months or so, or seeing that I just drive it in the summer months, once a summer.
Old Mar 26, 2004 | 02:39 PM
captainoblivious's Avatar
10k miles here.
Old Mar 26, 2004 | 03:22 PM
thepawn's Avatar
I have mine changed every 3 oil changes.
Old Mar 26, 2004 | 03:23 PM
Rob_02Lightning's Avatar
Every 3K with every oil change
Especially after this happen
Because the filter looked like this by 5k original new miles on the
truck
I'm sure it was bad gas, but I won't let it go over 3K anymore
next time it may not ONLY be the plugs that fail
Old Mar 26, 2004 | 03:30 PM
halflife's Avatar
Yo Rob,
Did those plugs break in the truck? If so how did you get the metal out of the cyclinder?
Old Mar 26, 2004 | 03:31 PM
USMCJon's Avatar
Someone give me a quick class on replacing the fuel filter. I figure I might as well do it tonight. Tools, prefered brand, blah.
THanks,
Jon
Old Mar 26, 2004 | 03:37 PM
O.K. Rob your freaking me out I guess I need to change it out again it's been about 15,000 miles and a year. I don't need to hear a big BOOM when I add all that timming to keep up with Rob
jeff
Old Mar 26, 2004 | 04:10 PM
grinomyte's Avatar
Originally posted by halflife
Yo Rob,
they should just shoot out the exhaust port eventually.
Old Mar 26, 2004 | 04:30 PM
kobiashi's Avatar
Old Mar 26, 2004 | 04:57 PM
AmoJohnny's Avatar
Every 15k. Runnin great.
Old Mar 26, 2004 | 06:02 PM
brain bypass's Avatar
THanks,
Jon
you just need a 5/16" fuel line removal tool. i got mine at pep boys for $5. the filter is on the driver's side frame rail under the cab. it is hard to miss if you look. i released the pressure from the line at the fuel rail schrader valve. i wadded up 2 shop towels and pressed down on the valve with a small allen wrench and the towels sopped up all the gas, didn't spill a drop. then disconnect the forward part of the filter using the tool, the back you have to take off the clip, then it pulls right out. make sure it is not directly over your face because it will spill some gas when you remove it. i just shoved some more shop towels on the end of it to soak up the gas. pop the new one in, and your done.
p.s. oh yeah, i change every 15K
