plasma booster
Old Mar 8, 2004 | 01:43 AM
Daves01L's Avatar
plasma booster
I have one of these sitting here staring at me. Wanted to know if anyone had any experience installing them. I don't like the fact that I have to attach a wire to each trigger wire on my coils,....is there a better way that is less of a mess?
Old Mar 8, 2004 | 01:59 AM
zbornac's Avatar
I did a write up back in the day. Lemme see if I can find it.
-Kimball
Old Mar 8, 2004 | 02:08 AM
zbornac's Avatar
here is the thread
https://www.f150online.com/forums/sh...ghlight=plasma
here is a pic of where I mounted mine.
you can see some of the connectors I used down below the unit itself.
-Kimball
Old Mar 8, 2004 | 06:03 AM
Rob_02Lightning's Avatar
Believe me you want to go zbornac's way
Other wise imagine this
First you must cut back the protecting cover around each and every coil wire connection.
Then you got to squeeze this connector in
Then you got to get in there with a plyers and close each connector (not always an easy task)
The you make the connection to each one via a female spade connector
Old Mar 8, 2004 | 06:11 AM
Fast Gator's Avatar
You'd be better off if you threw that "booster" in the closest garbage can or spent the money on a hooker
Old Mar 8, 2004 | 06:12 AM
You thought the back two plugs were hard to get to
NOW IMAGINE TRYING TO GET BACK THERE TO TRIM, CUT, AND MAKE CONNECTIONS
Oh Ya after step 1-8 making those connections
You simple find a good ground
Any your in
Old Mar 8, 2004 | 09:11 AM
skennett's Avatar
And after all that work you gained 1hp! Awesome! I have farts that produce more power than this mod.
--Steele
Old Mar 8, 2004 | 09:23 AM
RED 92's Avatar
Well stare back at it and.........try to sell it on E-Bay, maybe this guy will buy it, thats my installation tip
Old Mar 8, 2004 | 09:41 AM
--Steele
Steele you are 100% right that this IS NOT a Big Performance Mod, although it was originally marketed as one ???
With that said, anyone that does this Mod, DOES NOT do it for HP or Performance gains, We do it to save our Motors
Multi Spark / aka Plasma Booster WILL AND DOES create a more efficient cylinder burn, It DOES dissipate more heat in the cylinders, and it will give you a MUCH MORE FORGIVEN tune. But the most important thing it does, -->IS PREVENTS DETONATION
I admitt I wouldn't personally recommend this Mod as a big Performance Improvement, but I would for people looking to build safety into their tunes, or guys like me running Nitrous, it's an excellent and almost needed component for my way of thinking
Old Mar 8, 2004 | 09:55 AM
skennett's Avatar
Plus, those 8 green LED's are pretty sweet too!
--Steele
Old Mar 8, 2004 | 10:14 AM
I can talk frankly, we're like friends right ?
It was that Dam Name and yes those Lights
that suckered me in
Old Mar 8, 2004 | 10:25 AM
skennett's Avatar
that suckered me in
I knew it! Do they blink for each ignition or do they stay on all the time? If they blink that would almost sucker me in. I have a stack of cisco switches and routers all hooked up in my room cause I like the blinkies! And the white noise puts me to sleep.
--Steele
Old Mar 8, 2004 | 10:28 AM
Speedin Bob's Avatar
From: On the side of the Road attempting to explain 135 miles per hour
--Steele
LMAO!!!
bzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzz
Old Mar 8, 2004 | 10:44 AM
wydopnthrtl's Avatar
Now Rob...? Please explain to me how a devise that's triggered by the ignition system. Prevents *pre-ignition*??? Your saying that this gismo retards the ignition?
I don't know if you joking or serious?
Rich
Old Mar 8, 2004 | 01:45 PM
RED 92's Avatar
Rich
because it just works dude!!! it makes the ignition cooler or sumtin plus it completely burns the air fuel charge hotter
P.S. .........Swanson rules dude
