Installing a C-Notch
Old Feb 24, 2004 | 11:32 AM
TampaBlack99's Avatar
Supporting Frame
Jackstand before and after the frame notch
Removing Leafs from Shackles
Old Feb 24, 2004 | 11:35 AM
Cutting Frame, don't use a torch is it will weaken frame around the cut.
Ouch!
Undercoating Frame
Old Feb 24, 2004 | 11:36 AM
Drill and install farthest 2 bolts
Notch installed and undercoating drying
View from underneith the C-Notch... four more support bolts.
Truck drives great now, no more bottoming out.
Old Feb 24, 2004 | 12:05 PM
SVTRobG's Avatar
A helpful hint if you don't mind, on the drivers side notch I used the snubber bolt and a line clamp to secure all of the wiring that runs on that side of the frame. It's a tight fit but it works and no messy wires all over the place
Looks like a nice job dude
Old Feb 24, 2004 | 01:11 PM
I ended up running the 2 cables above the bolt you see on the top front of the driverside notch. On the reverse side is a bracket that the cables runs ontop of and prevents the cables from popping out. The 2 cables then can be pushed untop of the notch to further prevent movement. I will check in a week to make sure nothing has moved and come loose.
Thanks for the tip
The ride is nice and smooth now, almost like stock.
Old Feb 24, 2004 | 01:40 PM
62Lincoln's Avatar
Tampa, thanks for the pics. Two questions: what's your suspension setup, and which company's c-notch is that? I'm getting a Western Chassis notch installed this week on my HD, appreciate you sharing your experience.
Old Feb 24, 2004 | 02:03 PM
Casey02L's Avatar
Damn; Looks good
What kindof drop were you running?
Old Feb 24, 2004 | 02:23 PM
I'm running an all Western Chassis set-up. It comes out to a 4/4 drop.
I have:
WC 2" Lowering A-Arms
WC 1" Coils
WC Hangers and Shackles
WC C-Notch
So-Cal Adjustable Rear endlinks
Energy Suspension bumpstops and front endlinks
Herb Washers and Napa cam bolts
and Truck Trak Slapper Bars
Old Feb 24, 2004 | 03:14 PM
MEAT BAG's Avatar
The 2" a-arms and 1" coils gave you a 4" drop? Thats the setup i was ordering but didnt want to do more then 3".
Old Feb 24, 2004 | 03:51 PM
Intially I was level with other guys that had a bell-tech 3/4 drop. If you ever see a 3/4 bell-tech drop you will notice the front of the truck is higher than the rear. So this means just with the 2" arms up front your will be equal to a 3" drop. I wanted a slight rake, so I added a 1" drop spring.
You would be best just to install the a-arms.
