Apten or REM ported blower
Old Dec 18, 2003 | 07:47 AM
Griffin 01 L's Avatar
Waste your money if you want, but REM and Apten port the same thing. My dyno sheet was posted over at SVTperformance.com and it was deleted after the Apten followers got pissed off I posted it. My power numbers were throughout the powerband. Derek(SVTBlackbolt) helped me install it and was there when it was dynoed. As I have said before, Apten didn't re-invent the wheel, all they did was port the S/C. REM just followed their lead and is offering it cheaper....
I understand your reasoning though
Old Dec 18, 2003 | 08:09 AM
brain bypass's Avatar
does anyone have more info on the razor's edge port job? do they have an exchange program? how much is the core charge?
Old Dec 18, 2003 | 08:12 AM
fractaldragon's Avatar
There are different ways to port though. What we need now is to see them. I have seen the Apten port on both the inlet and outlet. If REM is doing the exact thing at half the cost, then why wouldn't they post pics? They would get all of Apten's business if they did! I am confused...several places are now offering port jobs and no one will step up to the plate and show what they actually look like, whether they are equivalent, and the advantages of the way they have done it compared to someone elses. Competition allows better products to be made and a better cost to the consumer. We have the competition...now we just need to see the products!
Old Dec 18, 2003 | 08:33 AM
The reason REM hasn't posted pics is because I was in such a hurry to install it I took it and failed to let them take pics. I can assure you it looks EXACTLY like Aptens. When I have time I will take off my T/B and take the inlet pics for you guys. The work was top notch
And I an by no means a REM cheerleader. They had the best price
Old Dec 18, 2003 | 08:51 AM
I will have Derek post my dyno sheet when he gets home tonight as well so you can see the power curve
Old Dec 18, 2003 | 09:37 AM
JeffsLightning's Avatar
You will have to take more off than the throttlebody to see the inlet.. Your not just talking upper plenum or as it's called throttlebody spacer are you? I have seen the inlet and outlet of the Apten. I have said before if ANYONE can send me a picture of the REM outlet then I will give a if they are both the same...So far one guy posting dyno numbers is not enough for most people. They will want more dyno comparisons or even better track results...There has been allot of this data with the Apten. I'm not saying REM is a bad way to go but just want to see if the extensive porting exists on the REM unit... Here is where to send the REM pic.... Thanks hud@mc.net
Old Dec 18, 2003 | 09:38 AM
TampaBlack99's Avatar
I am not sure, but I think REM ports the blowers by hand, while Apten uses a machine and this is why there is a cost difference.
All I can say is I ported the entire inside of my blower and plenum myself and noticed a huge difference over my stock unported blower.
I was hitting 13lbs of boost with just a 2lb lower and the graphite rotor pack.
Holes in case are welded shut also.
Old Dec 18, 2003 | 10:59 AM
JimIII@jdm's Avatar
Former Sponsor
Porting is Porting you will almost always see a gain no matter who ports it.
REM or Apten....both have made gains so whats the difference
By the way neither of these two companies where the first to do it.
Old Dec 18, 2003 | 11:52 AM
78f1hundo's Avatar
I would love to see the REM vs. Apten side by side picture. JimIII is right this is not a new idea, Apten just seemed to be the one right out the gate. REM price is very attractive to me. I can't afford the KB and a built block. I'm trying to see what I can get out of bolt on's and stock part's on a stock block.
20 to 30 rear wheel horsepower for 300 bucks.....SOLD!
I would love to see dyno result's for th HD, with a list of all mods.
Old Dec 18, 2003 | 11:54 AM
I would love to just see a port blower swap on a stock truck and some numbers.
Old Dec 18, 2003 | 01:31 PM
retics4me's Avatar
Let me guess JDM did it first
Old Dec 18, 2003 | 01:39 PM
Have you seen the OUTLET for the Apten? Just curious as many people haven't. I still would like to see a side by side comparison. Everyone here wants to see proof of gains before spending their money on a new mod. Proof or pics are all we need to compare...
Old Dec 18, 2003 | 01:40 PM
78f1hundo's Avatar
This is getting good........
Old Dec 18, 2003 | 01:46 PM
rscoleman's Avatar
The difference in cost is probably due to how the port work is done. REM uses a hand grinder, Apten uses a half million dollar 5 axis CNC mill. When you buy from a machine shop you're paying for machine time, so the recent cost jump in the Apten is likely due to the extra port work they've started doing over their early port jobs. When they digitized their newer version, more than likely it required multiple more passes with the cutter and several different bits. That adds more machine time and hence higher cost.
Old Dec 18, 2003 | 02:14 PM
JimIII@jdm's Avatar
Former Sponsor
No not saying that really; but we have and it'd be interesting to find out who did though!
