lowering
Old Nov 17, 2003 | 02:07 AM
01FordLightning's Avatar
lowering
I want to lower my truck but want to go with a 3/4 drop dose that mean i need to do a 4/5 th drop on a regular truck or a 3/4 drop on a regular truck also all i wont to do is change my front springs and rear shackels. I really like DJY1's drop but dont wont to cut anything i just wonted sonething i could do my self. also im rolling on harley 20" rims
thanks'
Justin
Old Nov 17, 2003 | 03:54 AM
SurfsUP's Avatar
My 2001 L also is running on a set of HD rims I got as a gift from my friend. I have them wrapped with Pirelli Scorpion Zeros (305/45/20). My L has the Belltech rear shackles and the Roush drop springs with Doestch tech shocks all around. I say the front has been dropped maybe 1 1/2" to about 2" and the rear is about 2" drop. Overall it gives the L a nice stance and is not too low. The L now corners a whole lot better and the ride is kinda stiff. Here is a pic of my L with the new setup:
Old Nov 17, 2003 | 07:25 PM
player19's Avatar
Compared to stock f-150 -- lightings are lowered .5 in the front and 2 inches in the rear for 99-02 -- then the 03 is only lowered 1 inch in the rear
Old Nov 17, 2003 | 09:54 PM
DJY1's Avatar
Justin, Regular F-150's do not come lowered 1 inch around like Lightnings. You are correct say you went with a Bell Tech 3/4 kit which is designed for Standard F-150's you are only getting a 2/3 drop. You should just buy the Sport Truck Direct 4/5 kit made for a Standard F-150 in order to get the 3/4 drop. You might have a hard time taking off the rivets on the rear Hangers they were a pain without a Air Chisel! If all you want to do is change your front coils and rear Shackels you will get a 2/2 drop my friend just did the Ground Force 2/2 kit made for a F-150 with just Coils and Shackles and his Lightning looks a little lower but not Slammed!
djy
Old Nov 17, 2003 | 10:02 PM
Jkstang78's Avatar
My truck has the Ground Force for the stander f-150 3/4 kit. The only problem is that my truck bottoms out on the shocks, so I have been trying to figure out how to fix this. I only had this truck 2 months.
Old Nov 17, 2003 | 10:28 PM
DJY1's Avatar
Jkstang78, I hope you are not using the Stock Shocks! Are you sure your rear end is not bottoming out on the frame?
djy
Old Nov 17, 2003 | 10:40 PM
Jkstang78's Avatar
djy
No there not stock shocks they are ground force shocks. I know this because, I had bought new ground force shocks, because I thought I had the stock shocks on it. When I took the old shock of it said Ground force on it. It is not hitting the frame anywear, It is definatly bottom out on the shock though. I only have about 1 inch of travle on both rear shocks. I have some stuff at work that will let me move the shock down. Its called kindorf and will let me use it as a shock extender. gunna see if that will help me.
Old Nov 17, 2003 | 11:21 PM
LightningCT's Avatar
Aside from the bottoming out, how does it handle...?? I'm interested in a drop, not sure which though....not necessarily for looks, but for cornering, etc...
Old Nov 17, 2003 | 11:47 PM
player19's Avatar
get the lower shock mount extenders from so-cal speedshop---- will recover about two inches of shock travel-- I have the roush kit with two inch belltech and needed them for the shocks
Old Nov 18, 2003 | 07:52 PM
Jkstang78's Avatar
Handles very good
Old Nov 18, 2003 | 07:58 PM
Jkstang78's Avatar
do you have a website for them.
Old Nov 18, 2003 | 09:15 PM
player19's Avatar
I don't know if they are on the website....
Socal
Old Nov 18, 2003 | 09:50 PM
PoorSvtMan's Avatar
do you have any more pics of your L with the drop? From the looks of the pic in your sig thats the exact drop im looking for.
Old Nov 18, 2003 | 09:56 PM
Jkstang78's Avatar
Here Also I forgot to say that those are 18 inch rims
