Why does it stumble?
Old Oct 6, 2003 | 03:08 PM
MHMCGILL's Avatar
Was out early yesterday morning for a run. With temps in the upper 50's the truck has alot more jump but with a problem. Sometimes on a WOT 1-2 shift it stumbles for a half sec or so then goes. I was wondering if by some chance I am hitting the rev limiter?
It's not the blow off, that I know and you can hear it and when I looked at the tach it is a full needle width or better in the redline. I was surpised how diff the temps affect the truck. New sticky pavement results in twenty feet of rubber. I guess lower temps and cooler rubber don't make for ideal traction. Any thoughts on the stumble?
Old Oct 6, 2003 | 03:17 PM
fractaldragon's Avatar
Either boost dump or torque converter lockup although the latter usually happens at 2-3 shift
Old Oct 6, 2003 | 03:29 PM
mrinaldi's Avatar
Sounds like the dredded torque reduction between shifts....The computer actually stops firing 4 of the cylinders for that split second between the shifts to help protect the tranny....Most chip tuners will turn that off for you unless you request that they don't
Old Oct 7, 2003 | 09:51 AM
MHMCGILL's Avatar
Hey thanks, I forgot about the torque reduction. Kind of sucks.
Old Oct 7, 2003 | 12:44 PM
Grimace's Avatar
Mine was "unloading" between shifts until I did the boost bypass mod. Now it holds steady and shifts like i have a v-body.
Old Oct 7, 2003 | 02:21 PM
MHMCGILL's Avatar
Thanks Grimace, but it is not the blow off "fart". The thing actually shuts down for a quarter sec or so, right after the "fart"
