Bottoming
Old Sep 29, 2003 | 01:26 AM
DJY1's Avatar
Speedracer5, It was not that hard to install the C-section with the right tools. I used a Plasma Cutter to cut the frame and a Super Heavy Duty Industrail Reversible Drill with Cobalt Drill Bits to drill holes in the frame. Took about 2 hours.
Good Luck, djy
Old Sep 29, 2003 | 03:14 AM
speedRacer5's Avatar
Another question.... What does this do to the value of the truck. Frame cutting seems a bit scary. What is you take on it guys.
Old Sep 30, 2003 | 03:01 AM
madferraristi's Avatar
If we were talking about a standard F-150 that might be used for hauling a bed full of gravel then there might be an issue in resale value from a notched frame.
However, a Lightning is not too likely to be used for general hauling so I wouldn't see it being a major problem.
Old Sep 30, 2003 | 09:44 AM
62Lincoln's Avatar
FWIW, every c-notch maker will tell you that a frame with a properly installed c-notch is actually stronger than the stock frame, so there is not a downside wrt longevity.
Old Sep 30, 2003 | 11:26 AM
Ayrton's Avatar
Ruslow has probably the beefiest C notch out there…
