Anyone running a 112?
Old Aug 22, 2003 | 09:20 AM
eatoncharged's Avatar
Banned
Originally posted by Calightnin
I don't know where you got this information but it is incorrect. The roots blowers, (stock or Works 112) do not make more torque than either the KB or the Works 140. In addition the torque curve is completely different.
Steve
on the contrary your information is incorrect neither of the screws will compare in low end torque to the roots
Old Aug 22, 2003 | 10:53 AM
RollinLimp2001's Avatar
Originally posted by Aaron_001
Is that why the 03 cobras make power easier than we do off the stock blower
The lightning and the cobra have the same blower the Eaton M112 but the cobra has DOHC compared to our single setup which makes the engine more efficient.
Old Aug 22, 2003 | 04:04 PM
Calightnin's Avatar
Tell you what ...check out Don Bolts, JL's or Charlies low end twin screw torque.
The roots (Works 112) will out low end torque the twin screw (KB or Works 140) breifly....but only boost to boost . However the twin screw is capable of producing much more boost than the roots and can out torque the roots at any rpm.
Steve
Old Aug 22, 2003 | 07:19 PM
Banned
not trying to argue here but chris himself told me that two identical trucks running boost for boost under 18 lbs, the 112 would beat the 140, over that and its toast.
by the way can i see your dyno chart and all of your mods cali??
ryan
Old Aug 22, 2003 | 07:34 PM
blown318's Avatar
ryan
Old Aug 22, 2003 | 07:55 PM
Calightnin's Avatar
Don did over 700# of torque if I recall with 16# of boost on his KB. Show me a 112 doing over 700# of torque.
Old Aug 22, 2003 | 08:01 PM
Banned
yea with what engine cams etc????
Old Aug 22, 2003 | 08:05 PM
Calightnin's Avatar
Well now your getting into semantics. I reacted to your comment.
Originally posted by eatoncharged:
"im just trying to figure out if i should go with a roots style blower for torque or the KB ".
This is incorrect. If you want more HP and more torque get the twin screw.
Old Aug 22, 2003 | 08:15 PM
Banned
well i guess maybe my question wasnt really too clear, i for a fact know that the roots style blowers create a lot of low end torque and screws typically dont create as much.
the thing is cali, the screws may peak at 700 but what rpm is that at, id rather have a constant 600 torque
Old Aug 22, 2003 | 08:20 PM
Calightnin's Avatar
That is also not so. The twin screw blowers hold the torque much higher through out the rpm range while the roots drops off sharply the higher the rpm.
Old Aug 22, 2003 | 08:24 PM
Banned
show me your dyno chart with all of your mods if you can
Old Aug 22, 2003 | 08:26 PM
Calightnin's Avatar
No.
Old Aug 22, 2003 | 08:27 PM
Banned
ok then dont say something if you cant prove it
Old Aug 22, 2003 | 08:28 PM
Banned
at least list your mods for the dyno run in your signature
Old Aug 22, 2003 | 08:35 PM
Calightnin's Avatar
Twin Screw
Roots
Note torque curve of Roots vs Screw. So which one holds torque and which drops? Which makes more torque?
