Is this fuel ok?
Old Aug 11, 2003 | 01:54 PM
ShadowLightning's Avatar
Is this fuel ok?
Hey guys, was looking into getting some higher octane/better fuel than this CA 91 octane crap out here for track use. I was thinking 100 octane unleaded would be perfect but I can't seem to find any that's close to me in the Sacramento area. I went to a motorcycle shop close by that a lot of race teams run out of and they have everything up to 116, but it's all leaded...except for some 114 octane trick fuel unleaded which the guy said was 106 octane on the motor. I was wondering if this was OK to run on my truck? Would I be ok to mix with 91 octane to get an 100 octane mix. I wasn't so sure because I see some of you running 100, I've even seen up to 103. But 114 seemed a little steep. Any suggestions?
Old Aug 11, 2003 | 02:29 PM
mofo's Avatar
Fuel
ShadowLightning, Check the Union76 stations,some carry 100 octane in there island pumps. Larry
Old Aug 11, 2003 | 02:37 PM
LIGHTNINROD's Avatar
If your L was tuned from the factory for 91 octane or if you have a chip tuned for 91 octane, using 106, 114, etc. will not gain you anything. In fact, because the higher the octane level, the slower the fuel burns; using it could slow your L down.
Dan
Old Aug 11, 2003 | 03:39 PM
I check all of the Union76 stations around here...NONE of them carry 100 octane at any of their pumps.
Old Aug 12, 2003 | 02:11 AM
promodlightning's Avatar
The definition of octane is the resistance to predetonation...if your motor doesnt need the octane you will not gain from it....if you are tuned for it than yes.....
Old Aug 12, 2003 | 03:53 AM
Flying Mofo's Avatar
Banned
A lot of 76 stations actually carry the 100 octane cool blue in 5 gallon cans. If your local place doesnt have it, they an order it for you.
Old Aug 12, 2003 | 04:04 AM
Thanks ****, I'll go down to the Union 76 on my lunch break tommorow when I fill up and ask em if they can do that.
Old Aug 12, 2003 | 08:35 AM
LatemodelRacer2's Avatar
Is 100 octane airplane gas leaded? I think i have heard it is like low lead but not lead free or something like that. It is 2.21 at the airport so thats not as bad as racing gas here.
Old Aug 12, 2003 | 08:41 AM
Banned
It does contain a small amount of lead but if you break it down with regular fuel, you should be ok. I know USAHOOTERS uses Av Gas.
Old Aug 12, 2003 | 12:13 PM
mswaim's Avatar
Follow this link to all 76 stations in CA that carry race fuel.
http://www.76.com/cgi-bin/b2cpt01/scripts/mapQuery.jsp
Old Aug 12, 2003 | 01:13 PM
Banned
I couldnt get that search function on 76's site to work.
Edit. I had to use the link off their store locator on the site to get it to work. So just goto 76.com and do it from there instead of the above link.
