rich & detonating ???
Old Jul 21, 2003 | 05:48 PM
RAN JR's Avatar
Question rich & detonating ???
Is it possible to run rich and still get detonation? I recently got a gadgetseller modified a/f gauge installed and yes I know it is not a wideband, but I feel it is fairly accurate for this comparison. I currently have a '00 with 90mm, ram air, 4# lower, vb, & chip. When I run the chip I hear detonation. I have sent it back and got the fuel mixture set to be richer. Well it still does it, so I have been running without the chip. It runs great. Absolutely no detonation even when towing my boat up and down the hills. Now that I have the gauge I have turned the chip back on a few times to see what it shows. With the chip OFF the gauge reads in the middle of the gauge at full throttle. With the chip ON it reads well over into the green rich area and still detonates. What could cause this? What should I have my tuner adjust? Any help is greatly appreciated.
Old Jul 21, 2003 | 05:58 PM
grinomyte's Avatar
yes possible, doenst matter how rich you run it if your using 87 octane (just as an example) youll get detonation. Sounds like you need to lower your timing some, but im no tuner so who knows, you have a place close by that you can get a nice dyno tune? Itll be fun in the least .
Old Jul 21, 2003 | 06:00 PM
soap's Avatar
Even with 100+ octane............with too much timing you will detonate also.
--Joe
Old Jul 21, 2003 | 06:01 PM
Silver-Y2K-SVT's Avatar
TIMING
Yup, timing, in addition to some other things, will do it.
Old Jul 21, 2003 | 06:02 PM
RAN JR's Avatar
So is there an easy way to check timing?
Old Jul 21, 2003 | 06:06 PM
grinomyte's Avatar
Ask your tuner. . .
Old Jul 21, 2003 | 06:09 PM
AutoTap?
Maybe hook up to AutoTap also and see what pops out.
Old Jul 21, 2003 | 06:29 PM
soap's Avatar
Re: AutoTap?
'Tap doesn't check timing.
You need a scan tool for the OBD 2 port. It will graph your timing charts.
--Joe
Old Jul 21, 2003 | 06:50 PM
RAN JR's Avatar
Thanks guys. I'll send the chip back in for another reburn and get a couple degrees pulled.
Old Jul 21, 2003 | 06:55 PM
LIGHTNINROD's Avatar
Timing too far advanced--probably but it could also be too 'hot' of a plug ? A 160* thermostat would help too.
Dan
Old Jul 21, 2003 | 07:25 PM
RAN JR's Avatar
Dan
I guess I should have mentioned the TR6s and stock thermostat. Good point.
Old Jul 21, 2003 | 07:44 PM
ken800's Avatar
My autotap plugs into the ODBII port and reads timing advance in real time... My ease did it, too.
Old Jul 21, 2003 | 08:06 PM
Damn Right!
That's what I'm talking about.
Old Jul 21, 2003 | 08:55 PM
soap's Avatar
Interesting
--Joe
Old Jul 21, 2003 | 09:38 PM
Speedin Bob's Avatar
From: On the side of the Road attempting to explain 135 miles per hour
Ken,
ignition spark advance parameter?
Bob
