Help! Waste Gate Adjustment?
Old Jul 12, 2003 | 02:17 AM
hslightnin's Avatar
Originally posted by LTNBOLT
So what you are trying to tell me is that as you go into the throttle your gauge doesn't go from vacuum to "0" to boost.
Don't worry about disconnecting it. Just adjust it like the instructions explain.
it does but not any where close to how it was explained
my gauge reads 0 around 110-115 mph
Old Jul 12, 2003 | 02:21 AM
LTNBOLT's Avatar
Cool
Run along and let the adults talk.
Maybe you can find a coke bottle cap to take apart or something.
Old Jul 12, 2003 | 02:29 AM
hslightnin's Avatar
Are you impling i dont no what im talking about
prove me wrong then U "adult"
Old Jul 12, 2003 | 02:35 AM
LTNBOLT's Avatar
Cool
You don't seem to grasp the concept.
I think we've said enough.
Old Jul 12, 2003 | 02:41 AM
hslightnin's Avatar
ok can you put the concept in lamens terms please
Old Jul 12, 2003 | 04:18 AM
clonetek's Avatar
i'm not sure layman's terms would help that guy..
Old Jul 12, 2003 | 08:43 AM
JeffsLightning's Avatar
a boost bypass valve set correctly will give a slight increase in boost AND build boost slightly quicker. Like I said for this to happen it had to be set incorrectly in the first place which some are/were. Remember vacuum opens the valve and lack of it closes it..
Old Jul 12, 2003 | 10:30 AM
l-menace's Avatar
what
who said that a non boost L is the same as a regular 5.4???
Not even close.
an L has less compression in the cylinder than a regular 5.4
and different Cams........
They might have the same block. and I'm not even sure about that.
