Upper Intake/EGR question
Old Jul 3, 2003 | 12:04 AM
C BROWN's Avatar
With all the talk about the intake spacers and lowering the intake air charge why is no one doing anything about the real heat source??? After a afternoon drive I did a little temp checking. The center of the plumn and was in the 140~150 range, at the TB it was around 130~140, the good old Eaton was around 160~170. And the upper plumn right at the EGR was well over 200 The EGR valve itself was over 220! This heat ended up moving throughout the whole plumn, and probably down into the blower just as much. At the very least I would think you would want to make a spacer to prevent as much of the heat as possible. If not remove it; which brings me to my main question; who has, and what are the in's and out's of removing the EGR other than it thoughs a code?
Old Jul 3, 2003 | 08:23 AM
FooFur's Avatar
ttt
Old Jul 3, 2003 | 08:51 AM
soap's Avatar
Recent EGR info
--Joe
Old Jul 3, 2003 | 09:47 AM
easterisland's Avatar
I don't have an egr valve or either of the sensors which connect to it. Daily driven and over 10K miles since I did this.
Old Jul 3, 2003 | 11:39 AM
C BROWN's Avatar
Anyone else running EGR less?
Soap; that discusion is what brought this up.
Old Jul 3, 2003 | 12:09 PM
cyntaxx's Avatar
Hmm I'm curious as well. Get rid of some of that useless clutter in the engine bay
Old Jul 3, 2003 | 12:11 PM
Konig's Avatar
I have been wondering what the cons are to doing that as well...
Old Jul 3, 2003 | 12:29 PM
superfords's Avatar
The EGR system is there to reduce NOX or oxides of nitrogen. this is done by LOWERING combustion chamber temperatures by recirculating spent exhaust gasses into the combustion process. adding already burnt (inert) exhaust gasses into the combustion chamber allows less room for fuel (air/gas). This "reduces the amount of burning in the cylinder" and therefore a smaller fire equals a cooler fire. the cooler combustion chamber temps produce less NOX.
the main drawbacks of removing or dissabling the system would be:
A. it's illegal
B. you are creating more airborne pollution
the main advantages? really none that I can see. The EGR valve is inoperative at idle and during WOT, so it doesn't affect acceleration or horsepower that I can see.
however, the idea of a phenolic spacer is somewhat interesting as this "could" keep some heat from the egr valve housing and egr tube from transfering over to the intake plenum itself.
the idea is interesting, but I seriously doubt that the amount of heat reduced would translate into any real hp/tq gains.
just my .02.
later,
chris
Old Jul 3, 2003 | 12:52 PM
I have changed my mind the egr valve is a good thing. Just like torque reduction and the stock pullies.
Old Jul 3, 2003 | 01:20 PM
C BROWN's Avatar
A. it's illegal
just my .02.
later,
chris
If reducing or removing that heat source is not going to do anything for you; why are people buying these spacers from JDM to reduce blower heat in the upper plumn? The EGR is making more heat than the blower by the quick check I did.
But, I think I am with easterisland; I am heading out to put my stock pully back on
Old Jul 3, 2003 | 02:57 PM
wizechef's Avatar
why? whats wrong with having more pounds of boost? what are you doing with you aftermarket pulley?
Old Jul 3, 2003 | 03:00 PM
More boost =more pollution=illegal
computer chip to use more boost and which isn't carb certified = illegal in CA
Long tube exhaust = illegal
Old Jul 3, 2003 | 03:17 PM
soap's Avatar
If I was in Vegas I would put money on the fact that he was kidding
--Joe
Old Jul 3, 2003 | 04:39 PM
C BROWN's Avatar
In my statement about the pully; I was just continuing what easterisland was doing. For those who don't understand it is a joke.
Old Jul 3, 2003 | 05:24 PM
FooFur's Avatar
can ya give us some tips on removing it?
step by step ? =)
