Water - alcohol injection
Here are some links to some popular systems
Carroll Superchargers
Aquamist
SMC
Bob Avallar
I forgot Snow
I was going to build my own system, but won't have the time or energy to do that for awhile. I'll prolly just wind up buying one. I know for a fact they work. I am not sure how well they work on the lIghtnings, but I guess we will find out soon enough.
Aquamist
SMC
Bob Avallar
I forgot Snow
You just have to be careful of what youre spraying. Methanol will pretty much eat through our intercooler is what im told. It is the best thing to use with water though.
Dentatured Alc is another option. I dont know if it has any effects on the intercooler. Time will tell when i start running it.
Both Alc and Meth will increase the octane level of your pump gas.
You can also run straight water. This wont help to increase the octane but it will help cool the combustion chamber and stop detonation.
Originally posted by promodlightning
I consider that a possibility, that water is being drawn out during normal cruising, but I think the amount of water actually being siphoned is negligible if it is happening at all, the pump is controlled by the hobbs switch and comes on at 10# of boost, I go through about 1 to 1 1/2 gallons of water mix a week in around 1 tank of gas ....the injection pump isnt supposed to allow this to happen either ...
You might want to talk to someone before you put it there!
Jody
Originally posted by Flying ****
You could probably use sals juice plate.
If you notice Sal's plate comes with "2" tappings,
1 for a wet nozzle
and
1 for a dry nozzle
I could put a dry nozzle right in that other tap
and inject right there
Hmmmmmmmm ?????
I'll have to think about that
I think that i will reposition the nozzle before the t-body on REMs intake tube,....as far as running denatured alcohol , it is recomended, the problem with methanol is that it is highly corrosive, 2 manufacterers that I emailed recomended either denatured alcohol or ethyl alcohol due to their non-corroding properties...another solution that I was thinking about is puting a NOS selenoid between the water pump and t-body so the engine cant draw water until the hobbs switch activates the selenoid to open.....
Originally posted by skennett
So, can you mix water/alch injection with nitrous?
The water/meth mix would be activated when the nitrous is activated. I personally have not used it with nitrous, I am just going by conversations with people that have used it and what I have read.
So, to sum it all up there actually could be good reason to run high octane fuel (such as VP 104) plus water/alcohol injection plus nitrous oxide injection?
I don't know if I would mix water and nitrous. Since nitrous turns from a liquid to a gas at -127* and water turns to ice at 32* you could potentialy turn you intercooler into a big ice cube
I'm sorta kidding and sorta not, I'm not sure what would happen, just thinkin out loud.
Dale
Dale
Dale
Dale
skennet
Yeah I know....water/alcohol.......and I was talking about something that has the potential to reach -127 degrees.
Dale
skennet
Dale
