Plugs
Old Jun 24, 2003 | 09:43 PM
kmad61's Avatar
Plugs
Iam getting ready to install a 4lb lower pulley.Will the stock plugs work?Or do I need a colder plug?The plug change on the L is a SOB!!!
99 Lightning
JDM Superchip
JL 4lb pulley
Catback
Cold air
Old Jun 24, 2003 | 10:43 PM
cyntaxx's Avatar
Either Denso IT20s or NGK TR6s gapped @ .034-.036.
Don't run the stock plugs for long.
Old Jun 24, 2003 | 10:58 PM
SVT_KY's Avatar
4# = BR7-EF ... Nice plugs ... and Sal has them at the shop
ready to ship ...
Old Jun 24, 2003 | 10:59 PM
SVT_KY's Avatar
PS ... I just set a new personal best for the eight plugs ...
only 2 hours and 10 minutes !!! YAY !!!
Old Jun 24, 2003 | 11:12 PM
Spanky99L's Avatar
rookie
Old Jun 24, 2003 | 11:14 PM
Rob_02Lightning's Avatar
Denso IT-22's @ .038 - .040
Old Jun 25, 2003 | 01:25 AM
hslightnin's Avatar
has any one had any troulbe runing the stock plugs
i have about 3k miles on stock plugs and no chip with a 4#'er
and she runs like a top
Old Jun 25, 2003 | 07:43 AM
todd abbott's Avatar
I think its just a saftey blanket, and a cheap one at that.
Old Jun 25, 2003 | 07:47 AM
Flying Mofo's Avatar
Banned
Densos = Over rated plugs that cant take 1 ounce of abuse.
Get the NGK BR7EF's. 2 Stages colder and a hell of a lot cheaper. Besides, they give you that detonation safety factor.
Old Jun 25, 2003 | 08:37 AM
NeedFourSpeed's Avatar
BR7EFs gapped at 0.038 and you will be happy
Old Jun 25, 2003 | 08:49 AM
tommylightning's Avatar
Well with a 4# pulley you can go with a few different plugs, the cheapest being the NGK TR6s. Depending on your long term goals (and driving habbits) you could go with either the IT20s or IT22s. The IT22s are 2 colder than stock. .036 - .038 gap.
The NGK BR7s are also 2 colder but you will have lots of idle misfires. They are not necessary for just a 4# pulley. Now spray some nitrous with the 4# lower and then you need the BR7s.
Hope this helps.
Old Jun 25, 2003 | 08:53 AM
01Lightning's Avatar
I am also running a 4# with no chip and stock plugs, also runs like a top. I plan to pull a couple and see what they look like soon. I have had absolutely no issues with pinging or anything else. However, if I was running a chip along with the 4# I would definately change to a colder plug.
Sammy
Old Jun 25, 2003 | 09:45 AM
TheRipper's Avatar
I installed a #4 pulley on my truck when it had 3k miles on it. After reading all the post about how stock plugs were so bad for the truck I finally changed them at the 13k mark to the Denso IT22's. Every stock plug I pulled looked perfect!!!! The truck does idle a lot smoother now with the Denso's and it does seem better in the upper RPM's. I would just pull a couple and see how they look.
