Better shock for our Ls than QA1s?
Old Jun 21, 2003 | 04:54 PM
  #31
Ayrton's Avatar
"Sliders" eliminate the OEM hanger/shackle combo altogether, and they are designed to stop the "slop" in the OEM set up. I can post some pics of them this evening, and they will lower a truck about 2" so that will give me about 4" total in the rear.
If you have dropped the rear of you truck then you will need to get a shorter shock than what QA1 shows for the Lightning. QA1 offers three different sizes that will work depending on the amount of drop. Just take a measurement before you order and QA1 will tell what size to run.
Old Jun 21, 2003 | 04:59 PM
  #32
Spanky99L's Avatar
Originally posted by Ayrton
Spanky are you talking about the PHP/Penske shocks?
yes
i was told they are a drag shock.
here is a crappy pic:
Old Jun 21, 2003 | 05:08 PM
  #33
cyntaxx's Avatar
Hmm probably won't go with sliders then, the Roush leafs are supposed to give a pretty significant drop already (3 inch I think?) and I don't want anything *too* extreme as far as ride height.
Thanks for the heads up about shock length, I guess I will have to be careful and research/measure some when getting the rear ones.
Old Jun 21, 2003 | 05:47 PM
  #34
Ayrton's Avatar
Let me know if you need any assitance....
Old Jun 21, 2003 | 07:11 PM
  #35
captainoblivious's Avatar
I forgot to add that that you need to get a set Stan's heim joints for the rear and when you order the shocks make sue you get the 5/8 thick rods....
I still need to order them
cyntaxx - if you are doing either the Hotchkis or Roush springs in the rear, don't bother with the sliders unless you want the rear low, especially if you do the Roush as they lower more then the Hotchkis. IMO, if your gonna stay with the stock leafs then the sliders are the best bet for lowering the rear.
Old Jun 21, 2003 | 07:40 PM
  #36
thepawn's Avatar
Ayrton is about 2" lower then me Cyntaxx. I'm tempted, but I'm not sure if I'd be able to get into my own driveway after that.
I am looking into how much work it would be to drop one more inch though.
Ayrton : You have anything in a way of a bumpsteer correction kit?
Dan
Old Jun 21, 2003 | 07:43 PM
  #37
Ayrton's Avatar
Once I get the whole rear finished I will be able to give some exacts, but at the moment 4" total is a good guess.
Old Jun 21, 2003 | 07:45 PM
  #38
LatemodelRacer2's Avatar
I have penskes on my race car if thatcounts
Old Jun 21, 2003 | 07:48 PM
  #39
Ayrton's Avatar
Daniel do you remember my rear brake project? I think I have found a easy solution to the hat problem, but I will make a call on Monday to be sure...
Old Jun 21, 2003 | 10:09 PM
  #40
thepawn's Avatar
OOOOOooooOOOOOOO *waits to hear*
Old Jun 21, 2003 | 11:24 PM
  #41
svt02's Avatar
cyntaxx,
I have the QA1's on all four corners. 2" drop shackles on the back.
Western Chassis Lower Control Arms on the front.
Bought my QA1's direct. With that type of drop I was able to use the standard length shock for the Lightning. The Western Chassis also comes with the End Links and New Bump Stops.
Truck handles better than new.
The big plus I got from the QA1's was that I could adjust all 4 until I got a ride that I could live with and that my wife was happy with. Our taste in suspension' differed. Then I can always change at the strip.
I am pleased with the QA1's. Had them about 10,000 miles.
Old Jun 22, 2003 | 01:06 AM
  #42
cyntaxx's Avatar
The setup I'm planning is Roush front coils and rear leafs with QA1s and *maybe* 2 inch drop shackles to level the rear out a bit more....
A little off topic but I was told by my friend that Stan's panhard is 255-275? Not 150 like I assumed (for some reason?)...just asking/confirming.
Old Jun 22, 2003 | 01:05 PM
  #43
thepawn's Avatar
I put that down in my original post as the cost, but I really had no idea how much it was, I couldn't remember at all.
Dan
Old Jun 22, 2003 | 03:00 PM
  #44
cyntaxx's Avatar
One thing I keep forgetting to ask:
I have rancho-style bars. Will I have major ground clearance problems with the drop? Anyone running a suspension like the ones we are discussing who have ranchos?
Old Jun 22, 2003 | 03:09 PM
  #45
thepawn's Avatar
You won't have any big clearance issues... there will be a little less, but it shouldn't be a problem unless you've got really BIG speed bumps.
Dan
