JDM Phenolic Spacers!
Old Jun 18, 2003 | 01:05 PM
  #46
Silver_2000's Avatar
Originally posted by blowntruck
Jim or Justin,
On Doug's picture, is that the way the blower sits on the spacer? With that slight gap, or is it not tightened yet?
$89 bucks is do-able.
they were installing it at the time but thats not a gap - The phenolic is just black at the edge. the full size pic shows it better
Doug
Old Jun 18, 2003 | 01:08 PM
  #47
blowntruck's Avatar
Oh aight, I see that now.
Old Jun 18, 2003 | 01:50 PM
  #48
TheWhiteKnight's Avatar
Question:
1. If the object is to straighten out the flow and cool would'nt a
longer spacer work better?
2. Could a nitrus injector be installed in this location?
P.S. I guess my origional question got deleated because I tried to add some levity to the post, sorry I'll try not to use any big words anymore.
Old Jun 18, 2003 | 01:59 PM
  #49
SVTRobG's Avatar
This was originally posted by Bad as L on F-150 last October regarding blower porting. Interesting stuff.
"Ok the outlet was remachined in a mill. I stayed with the exact same shape but pushed everything out .100 or we could just round it off to an 1/8 inch after grinding.
After the mill work on the outlet, I used a die grinder and a lot of patience and dupilated the stock shape wich is a fairly large radius from the inside to the outside.
As far as flow data, I dont have it in front of me (I'm at work) but from memory I can tell you that a stock blower case with a stock upper manifold flowed 491.6 cfm 10" of H20 and the full boogy unit with all the porting and reshaping and clay work inside, it flowed 661 cfm. So it is possible to see 25 to 30% increase in flow. And all of the work is centered at the turn, your trying to get the air around that 180 degree turn and then load the rotors with a full charge of air.
There is epoxy on the floor of the upper manifold to reshape the short turn rad and make it more robust if you will. There is a spacer between the upper manifold and the blower case (1/2 inch tall) that adds more volume to the turn and then the roof and side of the blower case itself are blended into the whole mess. The 1/2 inch spacer is worth a flat 30 cfm on any blower.
Have Fun
Dale-"
Hope that helps some.
Old Jun 18, 2003 | 02:35 PM
  #50
captainoblivious's Avatar
2 older threads on this subject:
https://www.f150online.com/forums/sh...hreadid=104706
https://www.f150online.com/forums/sh...threadid=92733
I think the second thread was the one Rob posted the quote from.
Old Jul 1, 2003 | 10:59 AM
  #51
ShaneMcKenna203's Avatar
Justin or Jim, anyone at jdm... can i get a pic of the egtra egr tube your getting for $50? I was going to go with the spacer only for $90, but b4 I order I want to know what I get for $140. I am getting the spacer just thinking now about the the egr tube 2. thanks, Shane
Old Jul 1, 2003 | 11:39 AM
  #52
IOPNER's Avatar
Get the one for $89, bending the tube is not a big deal. I did mine without a vise. Just a little leverage!!
Old Jul 1, 2003 | 12:07 PM
  #53
whip's Avatar
Ya, just use a vise! I condemplated heating and stuff but it all came down to just a slight bend and she lined up purrrfect-o!
Old Jul 1, 2003 | 12:47 PM
  #54
can I get a pic of the thing I need to bend? thanks, Shane
Old Jul 1, 2003 | 12:49 PM
  #55
soap's Avatar
No pic but the EGR tube is the stainless (?) tube that is about 1" in diameter on the driver side of the motor that runs from the EGR valve to the exhaust manifold. The EGR valve is on the driver side upper plenum. The tube is partially covered in black heat wrap.
--Joe
Old Jul 1, 2003 | 01:16 PM
  #56
grinomyte's Avatar
https://www.f150online.com/forums/sh...light=Phenolic
Check out that thread, Joe describes it right on. His is right below that ufo looking disc and has some black wrap on it about 6 inches from the top. Id circle it but no photo software at work. Hope that helps, it shouldnt be hard to bend.
Old Jul 1, 2003 | 01:24 PM
  #57
but it can be bent, not by hand but it can be bent to fit with the spacer?
Old Jul 1, 2003 | 01:27 PM
  #58
grinomyte's Avatar
Yeah, think of it like plumbing. Do anything you have to do so you can take a dump.
Old Jul 1, 2003 | 01:31 PM
  #59
The thing that needs to be bent is it in the top middle covered in blue wrap in this pic to the right of the blower?
a pic of it after the install....
Old Jul 1, 2003 | 01:32 PM
  #60
pic of spacer in place....
