JDM Phenolic Spacers!
Old Jun 17, 2003 | 08:01 PM
  #31
grinomyte's Avatar
those egr tubes are pretty tough to bend arent they? If memory serves me it looks like half inch pipe copper tubing right?
Old Jun 17, 2003 | 09:13 PM
  #32
captainoblivious's Avatar
Originally posted by cyntaxx
...I'm saying that the placement of yours isn't optimal...
It's main purpose is to help the air around the bend, and then help out heat reduction. What isn't optimal about that? If it was marketed a soley benefits from heat reduction, I agree there are better places to put it. But anything to help the air get around that bend is good.
[edit]Thinking back, dumb idea.[/edit]
I know a lot of people have asked for them. What would be really cool is dyno/track numbers comparing the phenolic spacer to a aluminium spacer to see if the insulation does anything for you...
I made a 1/2" aluminum spacer for my truck, haven't installed it yet. If I felt like buying this phenolic one I would do a dyno comparison. But honestly, I really don't think there would be that much of a difference.
Old Jun 17, 2003 | 09:56 PM
  #33
Bad as L's Avatar
Somebody has to "splain" to me what the phenolic spacer under the blower would do for the truck. First of all...if you do the spacer above the blower ( wich I have found to be very benificial) then how would you have room for a lower one also. (Hood clearance ??)
The blower is a belt driven heater....it blows hot air at the intercooler. So putting an insulating gasket between the blower and the lower manifold would do what ?? Is it going to keep heat from migrating into the lower manifold or do I have this in reverse. Help me out here. (I would rather see a copper gasket between the IC and mid plate but thats just me)
As far as phenolic for an upper manifold heat insultor, that is also pissin in the wind (IMHO) That upper manifold runs at almost the same temurature as the hot air that is constantly blowing on it from the engine fan. I would rather have the strength of aluminum in this area. Unless you have a cammed lightning, these engines pull a lot of vacuum, I would hate to see a phenolic spacer cave in after you snapped the throttle shut. Just a thought.
Dale
Old Jun 17, 2003 | 10:02 PM
  #34
Silver_2000's Avatar
Here is a picture of he spacer in action...
It should help some of you understand where it goes.
Old Jun 17, 2003 | 10:07 PM
  #35
clonetek's Avatar
doug... what is the "2...3...4" written on the intake for?
Old Jun 17, 2003 | 10:12 PM
  #36
Not sure - I think it is a part they used for R&D of some kind - Its not my truck.. It was Paul Gaminos truck from the Atlanta FFW race. A few more pictures here
http://www.talonclub.com/4images/cat..._id=55&page=15
Old Jun 17, 2003 | 10:47 PM
  #37
Originally posted by Bad as L
...First of all...if you do the spacer above the blower ( wich I have found to be very benificial) then how would you have room for a lower one also. (Hood clearance ??)...
Excuse to get a cowl hood (Ooops, I already have a hood sitting in the living room)
I would think that it would help prevent heat transfer to the lower plenum/intercooler, but lacking in the science area I can't say for fact if that would happen.
As for say a phenolic spacer between the heads and lower plenum, on the VW 1.8t engines they have a phenolic spacer that goes between the head and the intake plenum. Over on the boards somewhere is some proven data of power increases from this, and reports of the intake being cooler to the touch, and these are with turbo's running over 15psi with semi-efficient intercoolers (well the modded ones running over 15psi). Thinking about it may not do our trucks much good since the blower is sitting up there, where-as the 1.8t engine the turbo is on the opposite side of the intake.
Old Jun 17, 2003 | 11:52 PM
  #38
tallimeca's Avatar
hmmm
Hey Jim
When we come down on friday for some dyno/tuning time, why don't I put one of these on.
How bout this, we run my truck without the spacer, then we'll put one on and run and and get some numbers.
My truck is your run of the mill 2000 with all the bolt on's, running a 4# pulley.
This will give the majority of the lightning community something to go by and they can decide.
I have no built motor, no head work, and no cams, so this would be a good test. I'm willing to be the guinnea pig unless it's already been done.
Old Jun 18, 2003 | 12:40 AM
  #39
SCC2000L's Avatar
This is definitely an interesting part.
It is my opinion that since JDM made the product and is trying to sell it to all of us they should be the ones that prove that it works with some real numbers. You can sit here all day long and talk theories of why it works, even if they make sense, I want to see 'real' proof w/ dyno and track numbers before I would consider the purchase.
Old Jun 18, 2003 | 06:05 AM
  #40
Tim Skelton's Avatar
Originally posted by Jim@JDM
. . . You can not polish phenolic. I really don't appreciate your link to the useless mod thread. If you have any knowledge or experience to back up your link to the useless mod thread I would like to hear it because we use this mod all the time on our customer's trucks and everyone so far has loved it. It drops your plenum temperature after a 1/4 mile run 68 degrees. This means that the air going in to your supercharger is cooler which on a supercharged engine is a plus. . . .
The burden runs the other way. The consumer does not have to prove that a product doesn't work, the manufacturer has to prove that it does -- BEFORE it makes the claim. Check the FTC regulations.
So the plenum is cooler. So what? What does this get me? It's all about the HP, baby. I cannot see marketing any performance part without hard data to back it up. This is not a 3 AM infomercial.
And I know something else that can't be polished.
Old Jun 18, 2003 | 08:34 AM
  #41
MaxPower's Avatar
Originally posted by B4THNDR
Whats the matter with you cry babies, sounds like a bunch of Democrats. This is a free country and there is nothing wrong with trying to make a $$$. You guys are so quick to jump on Jim when he is just trying to make a living and make our trucks faster. $139.00 big F___king deal, when paul at rem offered you a 4 valve motor for I think $13000.00 with no dyno #'s there wasn't all this crying and bashing. Jim is a true enthusiast who believes in what he is doing. I have been to a few FFW's and I have watched Jim and Shaun work from morning to night on customers trucks, many of them not JDM customers. I have seen them take their time to help out many, for free. It is not cheap to travel around the country promoting your products. I have not been to any events where the other tuners are, so I can't say if they do the same, but I know that Jim and his crew is always helping someone out!!!!
I am quite sure you can make this spacer in your garage or at work for less than $89 or $139, but could you make them and market them and make a profit???? Who's idea???? If you had the idea, why didn't you do it???? Did you ever think about the cost of being in business??? I am sure you can buy one for a mustang for a lot less money, thats because there are a lot more mustangs. It cost a lot more to produce a 100 of something than it does to produce 10,000. Open a business and try to be succesful, I like to buy things as cheap as possible as do most people, but I also respect the fact that people have to make a profit to stay in business.
Mike
Long, but well said. I'm not one to stir the pot, but sometimes these threads get WAY out of hand. Jim NEVER made a HP claim, all he said is that it smooths out the transition to 'help' straighten the airflow, and keeps the upper intake plenum cooler during runs. Do you REALLY need any more information than that? He can charge whatever he wants, and those of us with pocketbooks to afford an L should realize that it's a small market (getting bigger with the introduction of the '03 Cobra and many of the same parts) so we should expect to pay a little more for smaller manufacture.
If you can make the part - go make it. Hell, if I was being bashed like Jim's products typically do, then I would probably have the very same reaction as he did. You can only take so much before you pop.
I know it wasn't an original idea, but he was the first to have the part made and tested for the L. Is there anyone else here that can say that?
Jim/JDM - Nice work on the part. I wish you success with your business and those who are loyal to your service.
Jeez...Sometimes I hate being the one who just watches these dramas unfold.
...my flame suit is on...
Old Jun 18, 2003 | 09:03 AM
  #42
lurker's Avatar
You can market a "performance" product without data - no problem. Just don't surprised if someone says it won't do *****. Actually, Jim should be the LAST person to be surprised by someone questioning a product.
Old Jun 18, 2003 | 12:32 PM
  #43
I cleaned most of the offf topic bashing crap out of this and reopened it at 2 members request. Lets keep it on topic.
Doug
Old Jun 18, 2003 | 12:38 PM
  #44
blowntruck's Avatar
Jim or Justin,
On Doug's picture, is that the way the blower sits on the spacer? With that slight gap, or is it not tightened yet?
$89 bucks is do-able.
Old Jun 18, 2003 | 12:49 PM
  #45
whip's Avatar
I've been wanting to do this for a long time! I really want to make my own, not just because I'm a cheap pr!ck (but I am) more so I can brush up on my machining abilities! Looks great guys!
