It's almost C-Notch Time!
Old Jun 17, 2003 | 11:23 AM
TampaBlack99's Avatar
Finishing the rear drop so the truck will not bottom out.
I can now drop the rear 5" with plenty of clearance.
Western Chassis C-Notch
S0-Cal Adjustable Rear Endlinks
Old Jun 17, 2003 | 12:25 PM
Ayrton's Avatar
Don't forget those nifty little heim seals for the endlinks.
Old Jun 17, 2003 | 01:19 PM
Where do I get them and why do I need them?
Old Jun 17, 2003 | 01:33 PM
Flying Mofo's Avatar
Banned
A c-notch
Old Jun 17, 2003 | 01:50 PM
SOME GOOD INFO:
I have been doing some research on the intronet on how to correctly install a C-notch for about a month now. I have found alot of professional use Plasma Cutters and others use the torch method. The instructions from Western Chassis (which I tend to believe more) say to simple use a air powered die grinder. The reason is the heat from the other two methods will actually cause the metal around the cut to be weakened.
Old Jun 17, 2003 | 02:24 PM
Ayrton's Avatar
A torch is very bad, but a plasma cutter will not heat up the surrounding material like a torch or welding. Bolt the C-notch in place then make the cut.
Old Jun 17, 2003 | 02:25 PM
Ayrton's Avatar
I don't have the link at work, but they keep dirt out and quiet down the links.
Old Jun 17, 2003 | 02:43 PM
SVTRobG's Avatar
Chris,
He can't do that with the WC piece. The notch itself is welded to the support bracket and is just as wide as the frame so you have to cut twice measure once...or something like that
Just examine the photos a bit closer and you'll see what I mean.
Old Jun 17, 2003 | 03:06 PM
Ayrton's Avatar
Duhhh
I am smart....no really.
Old Jun 17, 2003 | 03:28 PM
These things are insanse, there's 12 bolts that hold them in.
4 on the bottom and 8 on the side.
Old Jun 17, 2003 | 03:40 PM
Konig's Avatar
you're actually going 5 inches in the rear? Should look good but your front is going to have to go lower to match..which is a bit too low for me ... you should be barely clearing parking stops as it is
Old Jun 17, 2003 | 03:49 PM
No, but I can if I want to down the road.
I have a set of WC 2" drop springs at home waiting to be installed.
This should give me an additional 1" drop up front.
When the truck is done in about 2yrs I am thinking about just bagging the front and then setting the back to a 5" drop!
Old Jun 17, 2003 | 03:56 PM
Konig's Avatar
bags? aww man, thats gonna kill your cornering some, plus the ride quality will be kinda squishy... but you dont drive fast anyhow. ....oh by the way, the 2#er came in today, one day service...gotta love it
Old Jun 17, 2003 | 04:14 PM
Bagging is for when it becomes a Show Queen... kinda like yourself.
Old Jun 17, 2003 | 04:22 PM
Konig's Avatar
show queen? I race more than I go to shows... guess that makes me a "drag queen" ? That sux
