It's almost C-Notch Time!
Originally posted by TampaBlack99
Where do I get them and why do I need them?
http://www.sealsit.com/rodend.asp
Tampa I used a Rotozip with the cutoff wheel. But an air grinder cut off wheel will work. Make sure you support the rear of the truck behind C-notch and front of Cnothc well. If you don't Frame bending is not good. The holes are the hardest part of the whole thing. Make sure you center it over the axle when there is weight on the springs.
