Thought these things were fast
Old Feb 8, 2004 | 07:58 PM
  #31
bluballz's Avatar
Leave the f-1s at 25 psi go through the water but when you do drag the burn out out of the box a bit so u pick up some of that sticky rubber from the slick tire cars...they dont need the rubber all the way back there anyway.now being u have that sticky rubber working with the f-1s bring the rpms to 1500 third yellow floor it.i managed to get a 1.85 60' with a 12.75 e.t. with f-1s with a chip and filter.I pulled a mid 1.9 60' with a 13.2 e.t.bone stock full weigt so you sould be able to hook up,especially with that lid on the back.Use the test and tune to do just that otherwise youll never really find out what works.You should get a 13 sec pass out of that truck easy just play with it.
mike
02 true blue 11.98@112 best so far
JDM Enhanced
6#,thrttle body,heat exchanger,
chip,filter,full length exhaust,&traction devices
Old Feb 8, 2004 | 08:06 PM
  #32
bluballz's Avatar
My fault dam puter said it couldnt send it.You know your computers old when iit cant remember what just happened.
sorry bout the double post
Old Feb 8, 2004 | 08:07 PM
  #33
bluballz's Avatar
  #34
Deus's Avatar
Ahhh...make it stop
Old Feb 8, 2004 | 08:23 PM
  #35
bluballz's Avatar
sorry bout the double post puter said it didnt send
Old Feb 9, 2004 | 12:24 PM
  #36
Sharpshooter's Avatar
Re: Thought these things were fast
Originally posted by Deus
Ran my stock 03' L last night after airing down the rear tires to about 25lbs and also pulling the boost bypass, hitch, spare, and jack out. I do have a stereo and snug lid which pretty much makes up for the weight I pulled off. Anyhow, it was about 75F with 30% humidity and the best run I managed was....
60' 2.307
330 6.130
1/8 9.243
MPH 79.18
1000 11.943
1/4 14.229
MPH 98.58
My best 60' out of 6 runs was 2.23. I was under the impression that a high 13 was more typical. Am I about on par for being stock? Is Dark Shadow Grey slower? Could you fellas reccommend some cheap, warranty friendly mods to get me firmly into the 13s so I can actually wear my damn helmet and not look like a poser carrying it around
My truck stock. It is only 1/8th mile. Our mph in the 1/8th is almost identical.
I still had the spare and hitch, but also had the stereo box.
