Rear end question..?
Old May 6, 2003 | 02:23 PM
78f1hundo's Avatar
In our trucks, is the rear end a 9.75?
Is this the same as the reagular f-150's?
I have someone that has a brand new set of 3.73's that he bought for his f-150 and now he is not going to use them. So I'm going buy them from him if they will work.
So........HELP!!!!!
Will they work?
Old May 6, 2003 | 02:24 PM
Silver-Bolt's Avatar
9.75" is correct for the Lightning. Most 4x4 F-150 use the same, most 2wd use the 8.8"
Old May 6, 2003 | 03:35 PM
Robert B. Chuhran's Avatar
Lightbulb Rear end question...?
78f1hundo;
You might reconsider on the 3:73 gear swap in your " 99 "
as the expence in doing it just doesn't justify what you might
gain from it. Some say it won't help you and your RPM will be
higher on the e-way and just eat up gas. If your buddy's truck
is a 2 wheel drive its most likely a 8.8 gear set. I'm still using 3.55
and glad I never got the 4.10 I thought I had to have! Your call
if you want it. Might want an aluminnum drive shaft instead of the gear?
Old May 6, 2003 | 03:42 PM
78f1hundo's Avatar
I was told.....remember I'm no expert......This is one of the best mods to do if you want to go faster in the 1/4 mile for the 99's. It kind of evens the score with the 01's and up.
I don't know if what you are saying sounds right. I know of a couple of friends of mine that did this swap on the mustangs and man, what a difference.
I wish someone would chime in that has done this swap with result's........
By no means am I slamming you!
Old May 6, 2003 | 03:54 PM
Wink Rear end question..?
78f1hundo;
I would never think you had. If you swap, keep up the thread
and post any gain you get!!
Old May 6, 2003 | 03:59 PM
78f1hundo's Avatar
I was just being careful, too many closed threads.
I don't need anymore enemy's
AZ fun's Avatar
Skip the 3.73 gears go right into the 4.10s. I have a 00L and it made a huge difference. I will never go back. As for gas I haven't noticed a change but I never cared about it either
Old May 6, 2003 | 04:50 PM
Question Rear end question..?
78f1hundo;
As AZ fun said, if you are set on a change, that's what I would
do!! Go to the 4:10. Hope it won't whine on ya. Must be done
by a good rear end guy that can set the gear lash right!
Old May 6, 2003 | 04:55 PM
Neal's Avatar
Cool
HI!... It doesn't matter if the truck is 4x4 or 4x2. FORD did it like this : Any F-150 with the 5.4 engine has the STERLING 9.75 rear end. The 4.2/4.6 equipped F-150's got the 8.8 rear end. The LIGHTNING and the "99" to current F-150's with the 5.4 got the exact same 9.75 rear ends and front and rear 4 wheel disc brakes with antilock at all 4 wheels. They also use the larger F-250 brake booster.
