how to mount optima battery???
Old May 6, 2003 | 12:25 PM
clonetek's Avatar
i bought a yellow top optima yesterday & i'm trying to get it to fit correctly under the hood..
i ended up buying a universal battery tray, metal hook tie downs, and a cross bar from the 'zone.
i took the stock battery tray out (leaving the odd cannister that was behind it to flop around)
then used 4 screws to hold down the new tray.
i don't really like this arrangement at all.. i was wanting something thet held the battery down, so i could compete in a autocross at lightning fest..
help!
Old May 6, 2003 | 12:42 PM
Coldie's Avatar
What I did...
Was :
1) place the battery on the stock tray
2) mix up a full stick of epoxy putty in a bag
3) wedge the putty into the battery and the stock battery hold down.
It works great.
Coldie
Old May 6, 2003 | 01:06 PM
beastie's Avatar
Brooks, just relocate it to the back of the truck
When I put a red top in the Olds I have, I had to make it work, so I used some aluminum and make brackets.
Old May 6, 2003 | 02:57 PM
clonetek's Avatar
no relocating for me..
Old May 6, 2003 | 03:01 PM
clonetek's Avatar
Old May 6, 2003 | 05:03 PM
Neal's Avatar
Cool
HI!... I mounted my OPTIMA "YELLOW TOP" battery under my truck at the rear to help in weight transfer. I fabricated up my own custom battery relocation kit. Here's a few pics :
https://www.f150online.com/galleries...4-793-6941.jpg
https://www.f150online.com/galleries...4-793-6940.jpg
P.S : The small rectangular shaped black box behind your battery is actually a vacuum resivoir for storing vacuum to operate your climate controls when your truck is not running. I removed mine with no after effects. You just can't use the climate controls when the engines not running. Like who would want to anyway?
Old May 6, 2003 | 10:21 PM
clonetek's Avatar
thanks for the info neal!
Old May 6, 2003 | 10:43 PM
VINNIE's Avatar
From Eddie Marine
Go here
They have a bunch of colors
http://www.eddiemarine.com/cart/deta...38&CategoryID=
Old May 6, 2003 | 11:04 PM
clonetek's Avatar
how does it mount to the truck? screws?
Old May 6, 2003 | 11:06 PM
VINNIE's Avatar
Yep
Old May 6, 2003 | 11:42 PM
LatemodelRacer2's Avatar
what kind of grill is on your truck VINNIE? Where did you get it?
Old May 7, 2003 | 06:56 AM
VINNIE's Avatar
Well it matters which one?
I had the OEM ones painted blacK, but now I have a Stulle grill on.
Terry from pro glass put it on when he painted the Lightning.
VINNIE
Before
After
Old May 7, 2003 | 08:22 AM
Its the second one. Where did you get it?
Old May 7, 2003 | 11:12 AM
clonetek's Avatar
VINNIE: did you have to drill holes in the battery tray? did it come with screws? any pics of the bottom tray mounted?
thanks!
Old May 7, 2003 | 10:04 PM
Tim Skelton's Avatar
This trick piece is on sale at Jeg's right now for $89.
