...JLP 4" Drop Shackles INSTALLED!!...
Originally posted by m4d shifter
It's all about leverage. Think of using a prybar... you move the end alot and the pry end only moves a lil bit. same thing with out leaf spring axle setup... axle sits toward the front of the spring. you might be moving rear 4" up but your not gonna get it to move up that full amount. Now if you just did 2" hangars you would get closer to the advertised amount since the axle is closer to the hangar. If you do both then you get the SUM of the two exactly as your moving both sides.
to clarify things.
to clarify things.
Originally posted by Krix330cic(NJ)
Uh its called phuckin retarded that every web forum but this one that i visit, doesnt have an attachments link.
sorry, not gona upload pics then cut and paste links, they need to get with the program around here.
Whatever...
Even if there wasnt a vulnerability in PHP - I dont blame Steve for not allowing attachments. They bloat the size of the SQL database BIG Time and with 30,000 plus users it would get unmanageable and unstable very quickly... Everyone else seems to manage to use the Gallery's without too much trouble.
Doug
its called, "on vacation" brotha!
I guess I better watch my back, you'll be coming up in the post counts now
Originally posted by soap
Also the axle sits in the middle of the spring......not towards the front.
Axle sits 26" back from front spring eye and 32" forward of rear spring eye.
UPDATE
just remeasured today, one week since install..
started out at 34 1/2"
ended up today at 32" dead even.
still only a 2 1/2" drop total, but i guess ill just have to play with the leafs now..
