Short Block and KB or Longblock
Old Jul 4, 2003 | 03:19 PM
  #46
DL's Avatar
DL
I would say do the Longblock, with built 03 heads/cams. Might as well get the new heads with the extra threads for the plugs.
Add the KB next year at Tax time...
Old Jul 4, 2003 | 03:21 PM
  #47
DL's Avatar
DL
Originally posted by Struck in AZ
Two words for you Vinnie...CARILLO RODS!
Not Manley or Eagle???
Old Jul 4, 2003 | 03:32 PM
  #48
jagged edge's Avatar
Originally posted by seidler
Whats the deal with the suavy blower? I have been reading about a new blower that may be more cost effectiove than the KB. What is up?
Who knows??? You've read it so you tell us.
JE
Old Jul 4, 2003 | 04:57 PM
  #49
Blown93's Avatar
Vinnie you have enough input already, but I say longblock... Gives you something to look forward to in the future...
PEacE..................
(Jim)
Old Jul 4, 2003 | 05:29 PM
  #50
C BROWN's Avatar
Long Block, and a zex kit
Old Jul 4, 2003 | 06:07 PM
  #51
ken800's Avatar
The blower suavy is running is an entirely new cased blower which utilizes the rotor packs from the eaton. From my discussion with magnum, they are relocating the rotor packs out of the intake flow to cut down on turbulence. The also were increasing the blower case displacement. As far as the expected price, he told me they were thinking 1900.00 for the blower. I'm sure suavy's truck is performing well, but for anther 1000 bucks, I'll stick with the KB...
I'm still trying to make the same decision vinnie is. Do I put in a short block and a KB or go full long block and crank up the boost on the stock blower for now...
How far can you go with a KB on a shortblock? 500HP? 600HP?
Old Jul 4, 2003 | 10:17 PM
  #52
A shortblock is only the block crank rods and pistons basically.
The long block includes complete heads.
The most important elements are rods and pistons. with those two you can with a KB get 500+ or without the KB but using nitrous get 500+.
For 600+ you can get there a number of ways– with a KB, moderate quality piston, head work, some good valves and new cams you should be there, or a KB, high quality pistons such as CP's good 5 angle valve job and nitrous 125-150 will get you there too.
I opped for the later– just my choice ... cheaper, driveability (w/o juice only 500+hp) and did not want to sink money into those spark plug launchers and that's only my opinion.
I have Manley pistons and they will take anything you want to dish out but they are very noisy the CP's are the same alloy but better designed to be quite.
My 2 cents.
JE
Old Jul 5, 2003 | 12:14 AM
  #53
ken800's Avatar
Thanks, JE
So what is going to be my best bet to get a block with 03 heads and good valve work? Am I basically at the point of a full long block minus cams? Obviously, basic built shortblock would be the cheapest route, but I'd like to get rid of the spark plug launchers as well.
Ken
Old Jul 5, 2003 | 12:37 AM
  #54
Spanky99L's Avatar
My manleys are quiet. They only make noise when first started in the morning for approx 3 mins.
  #55
Thanks, JE
Ken
I don't think you can buy the '03 heads yet.
I'd get the CP pistons Manley rods, high quality valves with 5 angle cut for good flow, 6 pounder, nitrous the hell out of it and you'll see the 11's. When funds permited get the KB with at least 18 pounds of boost, 255 pumps, 50 pound injectors and you'll run with the big dogs.
Now when you do the heads and cams you'll pass them by.
Anyway, if it sounds like my game plan ... it is.
JE
Old Jul 5, 2003 | 12:46 AM
  #56
I am happy for you.
It has not been my experience and JDM switched from them because even they could not quite them down.
JE
Old Jul 5, 2003 | 12:49 AM
  #57
Spanky99L's Avatar
I am happy for you.
JE
Maybe i'm just special
Old Jul 5, 2003 | 11:12 AM
  #58
ken800's Avatar
Thanks, Jagged.
Are you just going to buy the parts and have a builder build your existing block or will you be buying a shortblock to your specs?
Who are you considering and what kind of pricing are you looking at?
thanks!
Old Jul 5, 2003 | 11:26 AM
  #59
Thanks, Jagged.
thanks!
Mine has been done. See sig. No need to buy a block short or long use yours unless you are giving the builder yours for a core.
I think you have this long block short block thing messed up as to what they are and your need for one.
JE
