What Slick Size
Old Mar 23, 2003 | 12:56 AM
tallimeca's Avatar
correct
355 is correct, i just goofed when typing.......i can hear the loading of the guns fom the firing range.....
I'm off to bed
Old Mar 23, 2003 | 01:28 AM
ib fast's Avatar
Originally posted by Flying ****
Come out to CA...
I would, but i am afraid of running over all those used anti war protester signs with my inferior et streets
Old Mar 23, 2003 | 04:43 AM
Flying Mofo's Avatar
Banned
Hell, not only do we have flower power people, theres a lot of other freaks that make owning a camera when visiting a necessity
Also, several of our tracks are losing leases. Property value
Old Mar 23, 2003 | 01:14 PM
owheelies's Avatar
Originally posted by frank2
I run a 26" and it is equal to a 4.08 gear.don't worry about running out of motor,went thru the traps at 4000 to 4500 rpm if I remember right.
You are actually close to running out of gear. Thesae trucks at your power level are NOT pulling very hard over 4500 RPM. No offense but if you get into the next level of power you will be much happier with the 28" tire. The ET's definately have the bite but once you get into the mid 12 sec. range you should be on the 28's, unless you are running 3:55's.
Just one guys opinion based on running both ,
Eric
