HELP!!!! I'm am just so MAD RIGHT NOW!!!!!! WTF!!!!!!!!!!!!!!!!!!!!!!!!!
Old Mar 7, 2003 | 04:58 PM
  #31
RTKILLA's Avatar
Originally posted by LIGHTNINROD
I may not understand what you're saying is the problem but if it's surges while holding the accelerator steady, my Haynes manual says:
1. Vacuum leak at the intake manifold or vacuum hoses.
2. Restricted air filter.
3. Fuel pump or fuel regulator defective.
4. Fuel inj. or eng. control systems malfunction.
Dan
My filter is kinda dirty, might as well try it I guess.
I can't find any vaccum hoses off or leaking anywhere.
I got new 255lph fuel pumps from PSP about a year ago so I would doubt it was though? maybe the fule regulator, but how often do those go bad? I have a spare adjustable one.
number 4, ***** thats allot to check.
Old Mar 7, 2003 | 05:10 PM
  #32
casper lightning's Avatar
Hey what's up Killa. Maybe the hose that goes to the fuel pump is ready to come off. A problem that i had. The factory used *****ty clamps. But I'm sure you used way better clamps when you installed the 255's. But you never know.
Old Mar 7, 2003 | 05:33 PM
  #33
RTKILLA's Avatar
good idea!
I got the entire upper off the truck off from the heads up, figure I might as well cean it.
Old Mar 7, 2003 | 05:40 PM
  #34
LatemodelRacer2's Avatar
How about the Throtle position sensor. Check the voltage on it even though i dont think it could cause that probem.
Old Mar 7, 2003 | 06:20 PM
  #35
Rob_02Lightning's Avatar
Originally posted by RTKILLA
good idea!
Joe, how do you do all this so fast ???
Plugs, plugs, and more plugs, MAF's, ENTIRE UPPER OFF TRUCK ?
Man I wish I had a dry INSIDE spot to work on mine.
I feel for you brother, have you tried the gas filter and Checking the coils yet ???? Remeber thats what mine did, when you ever so lightly touched the peddle is where the original dead spot was
I hope you figure it out today, God knows what you'll take apart if you don't
It does sound like it's gas or spark related ?
Old Mar 7, 2003 | 06:41 PM
  #36
SAlightning's Avatar
I had the same thing happen...it was a bad EGR.
Old Mar 7, 2003 | 06:44 PM
  #37
Coldie's Avatar
How can you tell if the EGR is bad?
Old Mar 7, 2003 | 07:06 PM
  #38
jgstang67's Avatar
symptons
RTKILLA, If it helps, I have ALLDATA at the shop and I can send you (via fax) the diag. chart for the sympton you are having. It would take forever to post it here. E-mail me if this would help and I will send it along. Jon
Old Mar 7, 2003 | 07:13 PM
  #39
wolf_creek_61's Avatar
im not tryin to insult your intellegence or anythign but have you checked to see if the fuel filter is on backwards this happens more often than you think .
