? for Gregg Evans
Old Mar 4, 2003 | 08:18 AM
FilthyMcNasty's Avatar
? for Gregg Evans
Gregg,
I've read a lot of threads and opinions about tranny fluid, but I thought I would get it "straight from the horses mouth" I will be installing your valve body and B&M pan this weekend and I want to refill the pan with synthetic fluid. Will it be o.k. to mix the synthetic with the residual non-synthetic fluid that is left over in the converter? I really don't want to have it flushed b/c it makes me sick to my stomach to have someone else work on my truck. Also, why does everyone seem to go with Mobil 1 as opposed to Redline or Royal Purple? Do they do something to their oil that no one else does? Thanks for the info.
Old Mar 4, 2003 | 08:28 AM
LatemodelRacer2's Avatar
you might want to try posting this is his forum on NLOC.NET
http://www.nloc.info/forum/forumdisp...s=&forumid=452
Old Mar 4, 2003 | 09:36 AM
SVT F15O's Avatar
Pull the plug on the converter and you will be fine. -Mat-
Old Mar 4, 2003 | 09:48 AM
Jace18's Avatar
They stoped the plug in the converter in mid 01 But if you have one then use it but do not overtighten it when you do. And i use Mobil 1 good stuff for the price.
Good luck
Jace
Old Mar 4, 2003 | 10:05 AM
SVT F15O's Avatar
Good luck
Jace
Mine was one of the last 60 trucks made in 01 and I had a plug. -Mat-
Old Mar 4, 2003 | 10:10 AM
LIGHTNINROD's Avatar
I have almost 25K on my Redline Synthetic D4 and I love it and, I believe my 4R100 loves it too. There have been very few mechs(tires, brake pads) to touch mine but I didn't worry about my local quik-lube shop as I stood right next to the flushing machine and the mech. IMHO, that's the way to have a fluid exchange done.
Dan
Old Mar 4, 2003 | 10:52 AM
Factory_Tech's Avatar
I get Mobil 1 synth for free, and that's why I use it. It's better than Motorcraft MERCON but I don't think it makes much difference to tell you the truth. It's worth the jack you pay for it if you live in the south because it holds up to heat better, but if I was paying, I'd use Motorcraft MERCON.
I personally think that Redline, Royal Purple, Amsoil (especially) and all those other "special" fluids are about like WalMart brand in an expensive bottle, but that's just what I think. Something about them just makes me flash "Infomercial"
G
