More Snow coming to NY, "BUT" I'm ready for it now
Re: Re: More Snow coming to NY, "BUT" I'm ready for it now
Originally posted by 99 SVT Bolt
everybody should get together and race their beaters.
Mine was free too
Mine was free too
Re: Re: Re: More Snow coming to NY, "BUT" I'm ready for it now
Originally posted by Don's Bolt
I will race your beater with mine
I'm glad everyones enjoying this
The worse part is it's dark by the time I get home so there's no time for nothing. But I did manage to make some emergency temp repairs. Ok so i couldn't fix the window so instead I put a 2x4 inside the door and drilled and screwed it in so if the window falls off the track it cant go below the opening, I left it so maybe 2" sticks out HEHEHEE
Then I put the door panel back on since I can open it with my finger from the outside now.
Then I forgot to mention that there isn't a got dam light inside. No dash lights, no dome light, no glove compartment light, NOTHING. So I go to the auto store for a dome light and they only have that bulb in Blue and Red (I GOT RED, )
I wish I could tell you it's better than no bulb, BUT IT'S NOT. Thank god I also bought one of those snake lights that plugs into the cig lighter, believe it or not the cig lighter worked, loose, but worked, so now I at least have some form of light inside. As for the Dash lights I find a fuse box with like 600 fuses in it and no diagram, so once again I resorted to another light, this time one that uses 2 AA Batts. I stuck it with velcro right inside the little area for the guage cluster (OUT OF SMILEY'S AGAIN)
HEHEHEHEHEHEHEHEHEHEHEHEHEHE
Once the weather breaks I'll get everything going no problem, it's chisling off that dam Lug I'm not looking foward to
I wish I could tell you it's better than no bulb, BUT IT'S NOT. Thank god I also bought one of those snake lights that plugs into the cig lighter, believe it or not the cig lighter worked, loose, but worked, so now I at least have some form of light inside. As for the Dash lights I find a fuse box with like 600 fuses in it and no diagram, so once again I resorted to another light, this time one that uses 2 AA Batts. I stuck it with velcro right inside the little area for the guage cluster (OUT OF SMILEY'S AGAIN)HEHEHEHEHEHEHEHEHEHEHEHEHEHE
Damn Rob......
free cars ain't what they use to be
Might be better to cut that lug nut off with a grinder, than beating it with a hammer and chisel, something about when its cold you allways smack your hand
Something about a blast of artic air coming in tonight
