Roush Suspension
Jerry, I put the aligment specs in the other thread. The caster and toe are the same left to right. The camber is different from side to side though.
Caster minimum 5.2 maximum 7.2
Camber left side minimum -negative 1.0 max 0.4
Camber right side minimum - negative 1.34 max 0.15
Toe - negative 0.10 to 0.16
I can fax it to you if required.
As far as instructions go, I usually reccomend using a regular repair manual for the R&R (remove and replace)procedure. It seems like you guys also have a detailed write up on here as well. If you guys need any help, just ask.
Eric
Eric
