Factory Tech V/B help
Old Feb 1, 2003 | 02:24 PM
Certified Drunk's Avatar
I just installed the Value Body and now the tranny slips, will not engage under 2000 rpm's. The fluid level is correct. I ran it through the gears upon restart, rechecked the level. went for a short drive and seems to shift fine, but slips under 2000 rpm's.
What did I forget?
Old Feb 1, 2003 | 02:28 PM
SVT F15O's Avatar
Did you put the filter back in>??? -Mat-
Old Feb 1, 2003 | 02:29 PM
LightningTuner's Avatar
Sounds to me like it's not torqued down properly. If the tranny is slipping, the only cause of that is not enough pressure to hold the clutch packs. The VB does not affect clutch holding, only the initial engagement firmness. Sounds like you are bleeding off fluid pressure and you need to spin the pump faster (higher rpms) to make enough pressure to engage the packs.
Old Feb 1, 2003 | 02:30 PM
SVT F15O's Avatar
Also you are checking the fluid level when the truck is running correct>??? -Mat-
Yep, the filter is installed
Old Feb 1, 2003 | 02:32 PM
SVT F15O's Avatar
Like Sal said....check the torque. Take it out and retorque it. Make sure the VB gasket did not get damged. -Mat-
Old Feb 1, 2003 | 02:34 PM
I used a inch pound torque wrench, I double checked them. 85 inch pounds.
Old Feb 1, 2003 | 02:36 PM
SVT F15O's Avatar
Reinstall your old accumulator body and see what happens....maybe you got a bad one>??? -Mat-
Old Feb 1, 2003 | 02:40 PM
wydopnthrtl's Avatar
Cool
One problem I had (I think???) when I did mine was an air pocket got trapped and caused some odd things.
But yours sounds to me like there is a "bleed" happening. Is there possibily debris between the body/gasket/case? Maybe some dirt or a burr?
WOT
Old Feb 1, 2003 | 02:42 PM
At least the new pan has a drain plug
Old Feb 1, 2003 | 02:44 PM
James-01L's Avatar
I have been researching the FT Valve body and plan to buy one soon.
I read this related link on NLOC:
http://www.nloc.net/forum/showthread...threadid=36025
The customer said it was shifting hard not slipping. However maybe it needs a day or so, either way I would send Gregg and email or post in his forum on NLOC (use above link to get there).
-James
Old Feb 1, 2003 | 03:55 PM
Update, took it all apart and put it back toghter. Now it goes nowhere.
I'm going to reinstall the old one, now
Old Feb 1, 2003 | 04:24 PM
Flying Mofo's Avatar
Banned
Old Feb 1, 2003 | 05:06 PM
WTH, I put it all back toghter with the original v/b and NOTHING
No go foward no go backwards, Me go nowhere It's so simple, what could go wrong?
Old Feb 1, 2003 | 09:57 PM
whtlight01's Avatar
How many Qrts did you put back in the trans? Didyou use Dextron 3? I heard it takes about 7 Qrts to refill. You have to check the fluid when the truck is at operating temp(hot) Make sure the V/B isnt sitting the wrong way I'm not sure ifit would line up but if it woul maybe you installed it 180 degress off. Lets us know
