Annoying vibration when crusing on the highway
Old Jan 26, 2003 | 01:26 AM
Lightning#838's Avatar
Angry Annoying vibration when crusing on the highway
Between 2100-2500 rpms when crusing on the highway there is a vibration that can be felt in the truck, but mostly through the pedals and the steering wheel. There's no noise with it, just an annoying vibration that will irritate the hell out of you. I must get rid of it!!! How
Old Jan 26, 2003 | 02:14 AM
ICULOKN's Avatar
Maybe a tire out of balance or the famous Exhaust vibration?
Old Jan 26, 2003 | 05:46 AM
cpeapea's Avatar
bent driveshaft? well that would probably do it at any rpm, but its just a thought...
Old Jan 26, 2003 | 10:37 AM
I just had the tires balanced a couple weeks prior to this vibration, it may be the exhaust.....and I have a 99 with the steel driveshaft, and I've never run on slicks, could it still bend?
Old Jan 26, 2003 | 10:41 AM
ICULOKN's Avatar
Hit anything by chance?
Old Jan 26, 2003 | 10:44 AM
Nope, nothing, I'm gonna get my driveshaft reblanced or rotated, whatever you call it. And see if that does it, if not another alignment at a different shop....Then I'll move on to the exhaust, and probably end up buying something else, I have the Borla Catback now, and want louder.
Old Jan 26, 2003 | 11:04 AM
Speedin Bob's Avatar
From: On the side of the Road attempting to explain 135 miles per hour
838
My former 99 had the same thing.. approx 75 to 85 mph.
Changed to an aluminum driveshaft, went away.
Keep the steel unit if you run drag radials/slicks w/out traction bars.
Bob
Old Jan 26, 2003 | 11:20 AM
Gen2 Lightning's Avatar
2001's and up also have this issue around 90 mph. It has to do with the exhaust from what I've seen.
Old Jan 26, 2003 | 11:33 AM
jgstang67's Avatar
vibration
lightning#838
You said you had balance done PRIOR to vibration, could a weight have come off a wheel? Just a thought.
Old Jan 26, 2003 | 12:50 PM
LIGHTNINROD's Avatar
See NOSTROMO',(SP?) post for help:
https://www.f150online.com/forums/sh...aust+vibration
Dan
Old Jan 26, 2003 | 01:42 PM
Thanks Dan! I bet you its the pinion angle. I just had the truck lowered not too long ago. NOSTROMO said that i need shims in between the leaf spring and the axle, can anoyone give me info on this.
Old Jan 26, 2003 | 02:48 PM
I did a 'search' on "shims":
https://www.f150online.com/forums/sh...ighlight=shims
There's more info using the 'search' feature..........
Dan
