Adjustable A/F on the fly
Old Jan 21, 2003 | 12:27 PM
Silver-Bolt's Avatar
Check this out. Looks like some possibilities here. Check out the ARC2 unit.
http://www.splitsec.com/index.html
Old Jan 21, 2003 | 12:36 PM
VinniePSVT's Avatar
Looks like it could definately have potential. Do they make a model for our engines? I didn't see it on their site.
Old Jan 21, 2003 | 12:55 PM
soap's Avatar
Sweet they have goodies to adjust timing curves also
--Joe
Old Jan 21, 2003 | 01:36 PM
Flying Mofo's Avatar
Banned
Its a hardware version of the Mafterburner that lacks full functionality of the rpm band and raising or lowering your fuel. Mafter uses the easiest software in the world to control your a/f. Its almost idiot proof. Better off with a Mafterburner and save yourself a few bucks in the process. My 02 anyways
Old Jan 21, 2003 | 02:06 PM
Fast Gator's Avatar
idiot proof?
Let me at it, I bet I could chit something up
Old Jan 21, 2003 | 02:29 PM
VINNIE's Avatar
Originally posted by Fast Gator
idiot proof?
No arguement there.
Old Jan 21, 2003 | 02:47 PM
Rob_02Lightning's Avatar
I like it, I like it. Would be nice to mount the unit, a sensor and guage, and be able to adjust AND SEE your A/F's on the fly.
AND WE ALL DO A LOT OF FLYING
Old Jan 21, 2003 | 04:18 PM
blown318's Avatar
idiot proof?
i agree!!! Nothing is idiot proof!!! I am sure I could f*&^ sumthin up also!!!!
Old Jan 21, 2003 | 04:25 PM
Banned
Seriously guys. You can make a pull on the dyno. Check out the chart.. Increase fuel here because your lean, or decrease fuel here because your fat. Sure, you could muck things up if your a complete idiot but the majority of you do still have some common sense. I think you would be spending a long time fine tweaking with ths ARC2 because the way you make your adjustments. Besides, all it takes is one of your buddies to twist the **** and your screwed. Or someone at a car wash.
Old Jan 21, 2003 | 04:28 PM
blown318's Avatar
sumtimes I dont know about that "gator" guy!!!!!!
Old Jan 21, 2003 | 04:33 PM
J15BIG's Avatar
i have been researching this unit, the MAFafterburner, and others like it. The ways these things work is they alter the reading from the MAF to the computer to eiter richen up or lean out your a/f ratio. That sounds harmless but according to sal, the maf [along with other sensors] is used to tell the tranny when to shift and do other things. so using one of these things has the potential to totaly mess up your transmission performance and possibly kill your transmission
check out sals post
https://www.f150online.com/forums/sh...hreadid=102608
Old Jan 21, 2003 | 05:05 PM
Banned
Well, theres quite a few Lightnings out there that run this unit without effects on their tranny. Not to mention all of the mustangs with auto's whos tranny gets their info the exact same way. No reports of failure.
Old Jan 21, 2003 | 06:19 PM
J15BIG's Avatar
im just going with what sal said....
Old Jan 21, 2003 | 11:20 PM
mjchip's Avatar
Hi,
Not to disagree with what Sal said BUT it is possible to make air/fuel corrections with the MAFterburner without seriously affecting tranmission shift patterns.
It is true that by altering the MAF signal, you end up altering calculated load and "calculated load" is used to determine fuel, spark, transmission shift points, etc..
However, unless you are doing major curve scaling, you shouldn't run into problems. We have a bunch of MAFterburners running on auto mustangs and also on a number of Lightnings without problems. The majority of people are using the MAFterburner only to do fine tuning.
Hope this helps,
MJ
Old Jan 21, 2003 | 11:31 PM
Silver_2000's Avatar
Originally posted by mjchip
Hi,
Hope this helps,
MJ
MJ
Please remove the link to your site from your post.
It is inviolation of the vendor rules you agreed to when you registered. If you have specific questions please email Me - Doug@SVTLightnings.com or Steve - Webmaster@f150online.com
Thanks in advance
Doug
