Hi I have a 2004 F150 the anti-theft code 13
Old 03-25-2018, 07:38 PM
Jayful's Avatar
Hi I just bought a 2004 F150 and code 13 is flashing on the Anti-Theft can anybody help me I don't know what I should do next thanks
Old 03-25-2018, 07:55 PM
Jayful's Avatar
Help
My 04 F150 I just bought it it's flashing code 13 on an anti-theft it will not start it shows the mileage I just don't know what to do next or how to fix it can anyone please help me thank you so much
Old 03-25-2018, 09:11 PM
Please don't double post...
https://www.f150online.com/forums/in...code-13-a.html
BTW: Welcome!
Old 03-25-2018, 09:23 PM
Jayful's Avatar
Sorry I won't double post again did not mean any harm I seen that link I read the information I'm still unsure what to do or what actually is the cause 4 code 13 is it the key or is it something else thank you
Old 03-25-2018, 09:25 PM
According to the website/documentation, it looks like it's something with the key. Is it a factory key or is it a no-name duplicate?
Old 03-25-2018, 09:38 PM
Jayful's Avatar
to be quite honest with you I have no idea I bought the truck at an auction I'm not sure if it is a duplicate or not my guess is it is a duplicate if that's the case can I get it to work or do I need a new key thank you
Old 03-26-2018, 10:26 AM
Jayful's Avatar
I still need help..
I just got back from the dealership I was told I didn't have the right key to start my truck I just got the truck on auction I ordered two new keys he said I needed 2. Is there a way to program the keys without taking them back to the dealership or do I have to take him to the dealership to program the keys any advice is appreciated thanks in advance
Old 03-26-2018, 12:26 PM
Bluegrass's Avatar
When you bought the truck, you must have never tried to start it. A mistake, or a fault has occurred.
The code 13 is the PATS key Transponder signal not received.
It's the wrong Key or the key is faulty.
You need get the correct keys or take the truck to a dealer, purchase 2 proper keys (not just any key) and have the system programmed in exchange for $$$$.
Then if no other faults, the motor should start.
The PATS system is a serious system that you cannot defeat.
It works or is doesn't let you run the truck because the computer must have the PATS signal to allow the motor to start.
After the motor starts, the PATS is 'out' of the control loop until the ignition is turned off, then it's back in again..
Good luck.
Old 03-26-2018, 12:31 PM
Bluegrass's Avatar
I just answered you in your original thread.
He should have told you what you needed to do same as I did.
No need to start another thread for this.
Stay in your original thread.
Good luck.
Old 03-26-2018, 05:50 PM
I recommend just taking the truck to a Ford dealer and have them sort it out.
Old 03-30-2018, 03:36 PM
Jayful's Avatar
OK now I have code 12..plz HELP ME.
So what does code 12 normally mean?how do I fix it thx so much
Old 03-30-2018, 04:39 PM
Bluegrass's Avatar
Code 12 is a Transceiver fault.
However, it depends on what version Pats is in the truck.
You cannot fix it.
You need dealer service for replacement and reprogramming and for keys if that is the fault.
Good luck.
Old 03-30-2018, 10:51 PM
projectSHO89's Avatar
It would be more correct to say "If yo have to ask, you probably can't fix it". A reasonably competent DIYer with some basic gear can reprogram the system if the system needs re-programming.
If it's the transceiver, that's a simple PnP replacement, no programming needed.
FWIW, I've never seen PATS lamp flash codes in any of the factory service manuals, I've only seen stuff out of the UK from back in the 90s. You're usually better off going into the HEC and pulling the DTCs for PATS through the cluster if you don't have the proper scan tool.
Old 04-03-2018, 01:59 PM
Jayful's Avatar
Update
I just received a phone call from the dealership replace the transceiver ring and it still throwing code 12 they tell me they don't know why can anyone else tell me or help me thank you
Quick Reply: Hi I have a 2004 F150 the anti-theft code 13
