AC/Heat control switch broken ?
Old Mar 15, 2002 | 10:07 AM
RKRives's Avatar
Unhappy AC/Heat control switch broken ?
I have a 99 XLT sport package truck.
the cold/hot temp control switch seems to have stripped itself out
I cant go from hot to cold. Is it just the **** that breaks or
the control rod.
The **** came off in my hand and the control rod is semi-circle shaped. I cant tell which part is broken.
Both still look OK
Anybody had this problem?
thanks
Old Mar 15, 2002 | 05:57 PM
J-150's Avatar
I don't know first hand, but I would say that the ***** are pressure fit onto the rod. There is probably a small plastic piece inside the **** that acts as a spring.
I say this because the ***** cannot be permanent mount. They must be removable if the climate control unit needs to come out for servicing.
A lot of Ford ***** tend to be push-on pressure fit.
Try pushing it back on yourself (pushing until you fell it lock)
