water in passenger floor board
I'm actually battling this right now. I've stuck a close hanger up in there like 3 or 4 inches and didn't hit anything, but due to it being so long I couldn't get it in there any further cause it kept hitting stuff in the engine.
Mine drips, but not alot.
I crawled under and took a look at the drain tube on my 2005 and that thing has to be well over a foot long. You guys might want to post something in the HVAC section and see if someone knows what ford recommends for cleaning out the tube.
Also, here is a link to a thread that refers to TSB (07-13-5) regarding 2004-6 models and problems with the AC drain causing water to leak back onto cab floor. Hope this helps, Keeks
https://www.f150online.com/forums/hv...ighlight=drain
sounds like AC drain to me,
i stuck over a foot of 8g speaker wire into mine and it helped, still not perfect. Ideally use something like a brake cable chucked to a cordless drill, and spin it once it is inside the drain tube.
mine will dry after a wile if i dont use the ac. but i ran a few feet of THICK zip tie and a clutch cable up there and i honestly feel like it leaks MORE now! i'm mad. i'm tired of it. and i REALLY dont want to take it to anyone
holy **** you guys. i ended up tearing my carpet out and figured out that where the ac drain goes threw the fire wall the tube was leaking and jsut pooring into my floor.. well.. i didnt know how to fix it so i took it to the shop.... $450 DOLLARS LATER. no water leak! pretty up set about the price. i could probaby rigged something up for it not to leak for 20 bucks and been just as happy.
GG, Look at the bright side, no more squishy carpet.
You got any pics of that leaking tube?
same thing happened to mine a few months after i bought it, it was the ac drain.
mine was covered under warranty.
And like keeks said, its not the heater core if it doesnt smell like antifreeze.
From the looks of the pics yours is clear clean condensation water. thats the ac drain.
haha. ya'll wana know some crappy luck. my warranty ended last week(had no clue) and they didnt wana help. oh well =/ last time i delt with them they helped me out alot. a bolt broke on my header so they pulled the bolt out and put a hole new header and they acadently dented my oil pan and they put a new one on all for free.. but this time when i went up there everyone was rude.
dealerships are so dumb. i travel an extra 20 minutes past the one in my town becasue of my EXHAUST LEAK and they told me that my REAR END was going out and they wouldnt help me becasue my BODY lift changed my DRIVE SHAFT angle.. we just laughed in there face and left.
I stopped going there after they told my mother why doesnt she take her truck to the dealer she bought it from when she took it in for a transmission malfunction and they had to warranty the tranny and install a new one. That was the last straw for me.
well i have the same problem but i found this tsb but i went to do it but i really can't find the plug that they are talking about can anyone help me out
http://www.ford-trucks.com/tsb/fullt...p?tsb=04-21-20
