Removing rear view mirror on 2007
Old Feb 14, 2008 | 06:12 PM
bgreer's Avatar
Finally figured out how to remove the rear view mirror on my 2007. For those that are interested.......Take a small flat head screwdriver and insert it in the opening at the bottom of the mirror attachment, push in as far as possible and at the same time wiggle the mirror and pull straight up. Came off without any problem and certainly didn't require enough force to break the windshield.
Old Feb 14, 2008 | 10:26 PM
labman1014's Avatar
sweet thanks, i will be needing to do mine in a few weeks....i am adding the new camera and have to change out the mirror....thanks again...
Old Feb 15, 2008 | 08:49 AM
ZEEKA's Avatar
Not to hijack the thread but since we're on the subject....
My rearview mirror has a bunch of wires running to it that run into small squarelike box that suurounds the base thats stuck to the windshield. I have a 2007 XLT Screw and as fas I know, I don't have a power rear view mirror option. What are the wires for? And what is the box that they go into?
Old Feb 15, 2008 | 08:58 AM
2005lariatky's Avatar
My rear view mirror has a bunch of wires running to it that run into small square like box that surrounds the base thats stuck to the windshield. I have a 2007 XLT Screw and as fas I know, I don't have a power rear view mirror option. What are the wires for? And what is the box that they go into?
Do you have the auto dimming mirror? If so it is the wiring for power and the sensors.
Old Feb 15, 2008 | 06:57 PM
ZEEKA's Avatar
I don't think I have it. How can I tell?
Old Feb 15, 2008 | 07:01 PM
Does it look like a normal mirror? If so then no. If not and it has 2 sensors looking eyes in the bottom then it is. Another way to tell is if someone is behind you and the lights are kind of a dim green color. Also you wont have the manual dimming flipper. Hope my rambling helped.
Old Feb 16, 2008 | 10:20 AM
labman1014's Avatar
the box on the windshield is your compass!!!! and the auto dimming mirror has 7 wires that go to it....
Old Feb 16, 2008 | 12:43 PM
ZEEKA's Avatar
That makes sense, thanks labman!
Old Jan 14, 2011 | 01:00 PM
rockstar1960's Avatar
Rear View Mirror-THANKS!
bgreer
can't thank you enough. I was probably about 30 seconds from disaster when I did another google search and found your post. Worked like a Champ!
Thanks again.
RS
