disabling passenger air bag
Old Jun 24, 2006 | 11:58 PM
Johnny340's Avatar
Question disabling passenger air bag
I noticed when I took the bezel from around the stereo off, there were wires for the airbag. I don't have an actual switch but I imagine if I had that option, the switch would be right there. Has anyone modified their truck to allow a manual passenger airbag disconnect switch?
Old Jun 25, 2006 | 12:42 AM
Podunk's Avatar
In the US, Its mandatory I beleive.
My 2000 Mustang had one, My 2001 Ranger had one, and my 2004 F150 has one.
I dont think you can get a car with out them any more.
Old Jun 25, 2006 | 12:45 AM
a15's Avatar
a15
I don't think it's mandatory in the US just customary..
My F150 has it but my 2000 Mustang does not. Neither does our 99 F250 RCab.
It's an option and yes I think you can just plug it up and get it to work.
Old Jun 25, 2006 | 07:34 PM
Johnny340's Avatar
Yes, that's what I'm talking about. I do NOT have that and would like it so I can switch off the airbag. I wouldn't have known the wires were there if I hadn't pulled that trim piece off. I presume, like most options, everything is wired but the switch was not installed at the factory. The wires seem to go to a little block from what I can see but it's on the left hand side?? Mine is an '03 Canadian model. I'm wondering if I got the swich or another plastic bezel part that has the switch, whether I can hook up those wires to it and have a functional airbag disabler switch...Should work, eh?
Old Jun 26, 2006 | 12:43 AM
Fritz_H's Avatar
IIRC, It's only in US vehicles without a back seat, because there's nowhere else to put a child. Pickups get them, Mustangs don't. Do screws have them? I know standard cabs and scabs do. Apparently the back seat in a scab doesn't count...
Old Jun 27, 2006 | 02:56 AM
SKRWZ's Avatar
Not true, I Have a 98' Lariat supercab and had a 97' XLT Supercab and both have them And bath of those trucks were Canadian built in Oakville Truck plant and sold in Canada as well,
Old Jun 27, 2006 | 12:07 PM
Norm's Avatar
Screws do not get the switch because you can use the backseat for child seats.
Old Jun 27, 2006 | 10:57 PM
Podunk's Avatar
You do realise that this switch has absolutely no affect on In-laws right???
Old Jul 2, 2006 | 05:33 PM
a15's Avatar
a15
It has nothing to do with having a backseat or not. It's an option that you can get. Some people like to be able to turn it off. Like I said,
03 F150 Scab. Backseat but I have the switch....
00 Mustant. Backseat but does not have the switch
99 F250 Rcab. No Backseat but doesn't have the switch.
I am going to bet that if you did a poll, there would be no corrolation (sp) between having a backseat and having a switch
Old Jul 2, 2006 | 06:07 PM
Raoul's Avatar
Certified Goat Breeder
25 Year Member
It ain't no stinkin option.
It's about the children's carseat.
F150 Regular cab = switch.
F150 Supercab = switch
F150 SuperCrew = No switch.(Put baby in back)
Mustang = No switch (Put baby in back)
F250 Regular cab = No switch ( It's a work truck, why are you taking the baby to work?)
"I heard the passenger airbag deployed and did a number on your kid."
"Yeah, I shoulda got that stinkin option. How could I have been so stupid? You think I should get a lawyer and go after Ford? They really didn't esplain that option to me. "
Old Jul 4, 2006 | 10:27 AM
scenaria's Avatar
I have a 06 screw. I believe theres a pressure switch in the passenger seat. when the weight exceeds a set amount the airbag is turned on otherwise its off.
Old Jul 4, 2006 | 11:36 AM
txnole's Avatar
05 scab - no switch (at least no visible switch in the cab) - The passenger seat contains a sensor which will disengage the pass airbag when the weight is less than ~40lbs. I might be off on the exact weight, but the new federal law requires the "dual stage" and weight detection in all 2006+ vehicles.
More: http://www.edmunds.com/ownership/saf...3/article.html
Old Jul 5, 2006 | 12:31 PM
Jrich1's Avatar
This is what mine does too, its weight sensitive
Old Jul 5, 2006 | 01:12 PM
Tical84's Avatar
I have a regular cab and the only thing I read about the airbag was that it disables itself if the occupent is less than X pounds. I didn't see an option to manually disable it although I didn't really look as I don't really care.
