Odd 2013 F150 Map Light Issue
Hey all
Have a 2013 F150XLT and recently noticed that one of the two map lights does not come on when you open the truck door. The light will work if you manually press it and turn it on no problem. Has anyone seen this before or have any idea why this would be? I removed the light and did not notice anything wrong on visual inspection. Are there two separate activation wires from the door switch for each light?
Thank you! I will try and replace the assembly
You find the issues with this? My 2010 is doing the same thing..
Have a 2013 F150XLT and recently noticed that one of the two map lights does not come on when you open the truck door. The light will work if you manually press it and turn it on no problem. Has anyone seen this before or have any idea why this would be? I removed the light and did not notice anything wrong on visual inspection. Are there two separate activation wires from the door switch for each light?[/QUOTE]
