Anyone have Rigid SAE D Series fog lights
Old 02-10-2016, 11:02 AM
MCDavis's Avatar
Right, but remember those two points are about 18" apart, so what looks like "below" at 25 feet could actually be aimed upward slightly. Also, you're going to get a pile of foreground lighting with these, so be prepared for that cause it'll actually make things in the distance look darker as the foreground lighting is playing with your eyes.
Old 02-10-2016, 05:44 PM
thelariat02's Avatar
You want a 2.5" drop at 25'. So if the fog lights are 20" off the ground on the truck at 25' on the wall the top of the cut off should be 22.5"
Old 02-10-2016, 08:04 PM
329PD's Avatar
What do you recommend the top cutoff be for the low beams in that setup?
Old 02-10-2016, 10:43 PM
Low beams work the same way. 2.5" drop at 25'
Old 02-13-2016, 01:25 AM
329PD's Avatar
MCDavis, how far away from that fence are you?
Old 02-13-2016, 06:15 PM
MCDavis's Avatar
I didn't measure, but I was in between the rows in the parking lots. I'd say it was about a truck length. Why?
Old 02-13-2016, 07:35 PM
329PD's Avatar
May use that as a guide. Having a heckuva time finding a 40 foot length of level ground. Parking lots in my town all slope.
Old 02-14-2016, 03:09 PM
MCDavis's Avatar
24-25' is the ideal distance. Somewhere between horizontal and 2" drop is what you want for fogs.
Old 02-14-2016, 03:50 PM
But figure 10' for the truck itself and you have close to 40'
Old 02-14-2016, 09:04 PM
MCDavis's Avatar
Ha good point. Been a long day.
Old 02-15-2016, 10:03 AM
329PD's Avatar
I figured you'd catch that.. I will mess with them today.
Old 02-17-2016, 09:28 AM
329PD's Avatar
Low beams. Rigid yellow covers.
High beams
Old 02-17-2016, 10:22 AM
They don't seem to wide, but the beam pattern is very tight, no glare, and bright. I like it!
Old 02-17-2016, 12:02 PM
MCDavis's Avatar
They gain width...a lot of it...once you're away from the truck. Claimed width from Rigid is 45* but they sure seem wider than that from behind the wheel.
Old 02-17-2016, 02:01 PM
Sweet! Well let's see some more pictures from like 40' against a wall or on the road
Quick Reply: Anyone have Rigid SAE D Series fog lights
