Need some reverse Light help
Old Jan 18, 2015 | 09:35 AM
Jims05Screw's Avatar
So I have a 2014 F150 that I am attempting to install some Vision Xreverse lights on, They are LED that draw next to no currant. The Issue I am having is that they blink on and then shut off as well as the OEM lights in the tail lights. I direct wired them with out using a relay or switch. I had this same set up on my 2012 and 2010 F150 with no issues at all. Can some one help me out
Old Jan 18, 2015 | 09:39 AM
MGDfan's Avatar
Direct-wired them to where, exactly?
MGD
Old Jan 18, 2015 | 10:35 AM
tied into the reverse light wires going to the tail lights. I am trying to figure out how to wire in a relay with out a switch. Not sure why the direc to reverse lights worked on my 2010 and 2012 but not the 2014
If I run a a positive and negative from the battery to a relay then splice into the hot side of the OEM reverse lights to act as a switch into the relay, that should work correct
Old Jan 18, 2015 | 10:49 AM
MGDfan's Avatar
So - direct to the positive-side of the reverse bulb socket, correct? And Grounded to the chassis?
Likely Difference between yer 2010 and 2011:
Originally Posted by Steve
The 2011 you have the FET that controls the truck's reverse lamps, so if you add any load to this, it might turn the FET off ( thinking it is a overload issue ).
Post current spec fer the light yer using.
Relay will indeed work - and all of the wiring info you need was in that thread you already viewed: https://www.f150online.com/forums/il...hting-mod.html
Ensure all runs to the back of the truck are run through protective wire loom, with soldered/waterproofed connections, and fused appropriately.
No need to run a negative wire all the way back there - there are convenient chassis ground points out back you can use.
good luck
MGD
Old Jan 18, 2015 | 10:58 AM
All the post I saw had the wiring with a switch. I dont want the switch. So you say dont run a negative wire from the battery back. Just ground it in the rear of the truck. Using the Hot side of the OEM reverse lights a the switched power to the relay is correct
Old Jan 18, 2015 | 11:05 AM
MGDfan's Avatar
Yep.
You need to decide what to use as the +12vdc source, (switched or unswitched - hot-in-run, acc, etc) that the N.O contacts will use to actually drive yer reverse LED's.
MGD
Old Jan 19, 2015 | 09:32 AM
I was planning on tapping into the OEM reverse light positive side source to go to the switch power of the relay (86 Pin) on a standard four pin relay
Old Jan 19, 2015 | 09:41 AM
MGDfan's Avatar
Pin 86 is the coil ( Pin 85 the coil return). So - yer running +12vdc direct from the battery then ( to connect to Pin 30 )?
MGD
Old Jan 19, 2015 | 11:40 AM
correct pin 30 direct from battery, Pin 85 ground, pin 87 power to new LED reverse lights, and Pin 86 switched hot power from OEM reverse Lights
