Quite the hassle but it was worth it. (Puddle light pics)
Old 10-17-2014, 11:50 PM
rpm0024's Avatar
Cool Quite the hassle but it was worth it. (Puddle light pics)
This ended up being quite the hassle, however it was worth it without a doubt in my mind. Looks great too. Can't wait to get all the interior led bulbs!!!! Freakin shipped from China.
Ryan.
Old 10-25-2014, 12:27 AM
Uin2it's Avatar
Was your truck not equipped with them stock? Mine isn't either and I have been debating adding them.
Looks good!
Old 10-25-2014, 10:52 PM
rpm0024's Avatar
Money well spent. No they didn't come stock. I bought these exact ones.
Cutequeen 30cm LED Car Flexible Waterproof Light Strip White (pack of 4) by CUTEQUEEN TRADING
Amazon.com: Cutequeen 30cm LED Car Flexible Waterproof Light Strip White (pack of 4): Automotive Amazon.com: Cutequeen 30cm LED Car Flexible Waterproof Light Strip White (pack of 4): Automotive
Cheap and they work well.
Any questions let me know. Hardest part is running all the wiring.
Ryan.
Old 10-26-2014, 04:28 PM
ak_cowboy's Avatar
I thought you did the factory puddle lights under the mirrors.... What wire did you tap into?
Old 10-26-2014, 10:52 PM
rpm0024's Avatar
No they're under my doors. I tapped into the wire up in the headliner where the map lights are. They run with the cycle of the other lights so they're not on all the time. Really happy how it turned out but I had to pull the pillar down and fish the wires down into the access panel and wire everything up under there. It looks super clean other than the wires running under the doors and over the door jambs.
Ryan.
Old 10-27-2014, 08:13 AM
tg150's Avatar
Pretty cool.. I did something similar to this to my truck in 2006 . Only I used Rampage under door safety lights..
Like these..
http://www.yourhotcar.com/prod/Rampa...506000/796020/
Old 10-27-2014, 09:37 PM
rpm0024's Avatar
Did you have to drill yours in? They seem about 10,000x simpler than all the finagling I had to do!!
Ryan.
Old 10-30-2014, 11:40 AM
tg150's Avatar
Ryan.
Yes sir you do.. I fished my wires from inside the door through the door boot. Ran the passanger wire to the drivers kick panel wire harness and tapped into the dome light wire. Then the drivers side I tapped into the passanger wire that I tapped into the harness. Did this many years ago.
Quick Reply: Quite the hassle but it was worth it. (Puddle light pics)
