2012 hids?
Old Sep 24, 2013 | 01:07 PM
speedstang's Avatar
There is no cheap way about it. Unless you buy a kit to put in your stock lights, which nobody will recommend.
http://www.projectoretrofits.com/
You can buy them already dun. If your stock headlights are in good condition, I believe you can send them in as a core and probably spend around $500.
Old Sep 24, 2013 | 08:58 PM
FX4Matt's Avatar
so by the looks of it my only option will be retrofitting if i want hids the right way. but that much money isnt an option at the moment. so what recommendations would everyone have for upgrading my stock halogens until i have the money for a retrofit.
Old Sep 25, 2013 | 10:03 AM
speedstang's Avatar
Check out the sticky on top of the illumination page. Headlight bulb guide.
Old Sep 25, 2013 | 06:20 PM
Raptor05121's Avatar
I need to update my guide.
My recommendations:
Philips XtremePowers or Sylvania Silverstar Ultras.
Amazon.com: Philips H13 9008 X-treme Power Headlight Bulb, Pack of 2: Automotive Amazon.com: Philips H13 9008 X-treme Power Headlight Bulb, Pack of 2: Automotive
Amazon.com: Sylvania H13/9008 SU SilverStar Ultra Halogen Headlight Bulb (Low/High Beam), (Pack of 2): Automotive Amazon.com: Sylvania H13/9008 SU SilverStar Ultra Halogen Headlight Bulb (Low/High Beam), (Pack of 2): Automotive
The Ultras have a blue tinge to them that gives them a whiter light, but they are only guaranteed for a year (you should be replacing your headlamps every year anyways- two years at the most [Halogen cycle is very inefficient]). The Philips last longer and they both have the same amount of lumen output. If you've got stock bulbs, either will be a definite improvement.
Old Dec 13, 2013 | 11:43 PM
Jdjjanzen's Avatar
How did you wire the hids into the stock headlamp wire?
Old Dec 14, 2013 | 12:00 AM
MGDfan's Avatar
Wow.
Nice post. No 'Hi', no 'please' and no 'thank-you' .... You seriously expect Help, buckwheat?
And - What specific HID's are you referring to, on what specific truck model? We ain't mind readers, y'know.
If it's a retrofit - just follow the instructions supplied by the kit's manufacturer.
However - If it's a Crap PnP system, find the nearest garbage can and donate it to Oscar
Jeeez ... is this more of that "afluenza" crap that's goin' around?
