08 super duty tail light conversion
Old Jun 7, 2011 | 01:02 PM
Blue-02-2wd's Avatar
i want to convert my tail lights to the 08 superdutys what do i need to do this on my 02 f150 is there any one who sells a kit for the wiring harness to extend the reverse lights?
Old Jun 7, 2011 | 01:10 PM
dirtyd88's Avatar
Talk with thejake1989. He can tell you what you need to get this done.
Old Jun 7, 2011 | 03:33 PM
Raptor05121's Avatar
If anything just cut the lead and ground wire going to the reverse light socket and splice in an extra foot or so of wiring. Its not that hard and much cheaper/easier/faster than buying any sort of extension
Then of course you need the lights themselves.
Old Jun 7, 2011 | 03:48 PM
dirtyd88's Avatar
The reverse bulb requires a different bulb base though. You have to either buy the socket from Ford ($$$) or find a wrecked 08+ SD and cut the pigtails off.
Old Jun 7, 2011 | 07:13 PM
i found the bulb connectors from LMC truck about 12.00 for each side i ordered them today.
Old Jun 7, 2011 | 11:41 PM
ELVATO's Avatar
Is it the 921s? When I did the 03 to 07 Expy taillight conversion, I just tapped off the 3156 (keeping it off to the side) and used a 194 base with wires.
Old Jun 7, 2011 | 11:57 PM
Halverso_99's Avatar
They are very easy to swap, you just need to bend down or cut out a piece inside the bed, and then swap the reverse light pigtails. I love my SD tails.
Old Jun 8, 2011 | 09:18 AM
piggington's Avatar
Yes, this was a easy mod to do. Bought 2 new bulb bases from LMC truck, added some more wire and used Dremel a bit.
Old Jun 8, 2011 | 10:39 AM
where did you guy purchase your sd tails from. I was thinking from ebay LMC is way more expensive but you know how the old saying goes you get what you pay for.....
Old Jun 8, 2011 | 11:13 AM
piggington's Avatar
Bought mine from eBay for $40 (pair) + $14 shipping. New OEM Ford part.
Old Jun 8, 2011 | 05:04 PM
Yeah but they are made in the same factory using the same processes. "You get what you pay for" describes comparing two different manufacturers.
Old Jun 8, 2011 | 06:00 PM
well bought the 08 lights(ebay hope they look good) piggys/connectors from lmc extra length wire and led back up bulbs and led break light bulbs.(hope the led bulbs look good never used leds before) if any one used led's let me know how they look.
Old Jun 15, 2011 | 03:00 PM
well there installed! Looks awsome Led bulbs Look like a millon bucks. Only thing i need to do is buy new relays for the blinkers because they blink like one is out. But other than that one of my favorite mods so far very suddel change but totally changes the look of the back of the truck. Thanks for all the help guys.
Old Jun 15, 2011 | 03:04 PM
Care to post a pic of the LEDs? Unless you know what you're shopping for, you may get good or bad results.
Old Jun 15, 2011 | 05:23 PM
i wll pull them out later tonight and post a pic bought them from ebay but there built pretty well.
