Raptor's LED Taillight Retrofit
Old Apr 29, 2011 | 08:09 PM
  #46
I will have two LEDs aimed at a 90* point from the rear of the vehicle. This satisfies FMVSS section 108. But if you go look in Patman's build, he omitted this part.
actually i have a side facing running light, which is the chrome/red bulb up top.
and the whole lens glows for the "blinker" and can be seen from the side, even though the side facing blinkers are not on any Range Rover, or 10+ LR product
That being said........... I was gonna keep quiet about this but since i like making raptor my bitch, here's what ive been working on in my spare time lately.....
Added another pocket between the brake and reverse light to allow for an incandescent running light
Old Apr 29, 2011 | 09:12 PM
  #47
Raptor05121's Avatar
They're not going to be on most vehicles. FMVSS section 108 dictates that running lights (not blinkers) must face 90* from the centerline of the vehicle. Looking at some google images, every 2010 Range Rover taillight has either a strip of LEDs conforming to the curvature of the tails or a split in the rear facing running lights to allow bleeding (similar to our housings)
Looks good, but no offense, I just don't like the "cut & paste" job. Rather than make the housing compatible for the lights, I'm making the lights compatible for the housing
Old Apr 29, 2011 | 09:43 PM
  #48
having my chrome red running bulb rear facing, but you can see the side of the bulb from the side of the truck is exactly how the factory F150 tail is setup
it will be finished off better, same process i used on my tail lights, it looks rough when its in the middle stages.....
Old Apr 29, 2011 | 11:59 PM
  #49
Halverso_99's Avatar
Looks great pat.
Old Apr 30, 2011 | 08:04 AM
  #50
papajohn's Avatar
i think these guys might have something to say about that one
http://www.youtube.com/watch?v=E3NXx9lPG4o
Old Apr 30, 2011 | 05:11 PM
  #51
The PWM/Vreg has arrived- I will begin assembly of it tomorrow (with plenty of pics). I'm still waiting for the LEDs to arrive. They're still in Texas after four days.
Old May 1, 2011 | 02:23 AM
  #52
DanielWalker10's Avatar
im going to see about stripping the vht off of my factory tails. if i can do so and make the lense look decent enought to be professionaly smoked, i might be sending them to you to make some if all go wells on your project. goodluck btw.
Old May 1, 2011 | 09:52 AM
  #53
DarkShadowSTX's Avatar
Old May 1, 2011 | 12:27 PM
  #54
Sounds fine to me. Just pay for the parts, shipping, and little on the side for mwah and I'll gladly do them.
I'm back from my girlfriends house. It's time to get started
PWM:
Backside:
Vreg and potentiometer:
Now I will begin soldering. Stay tuned.
Old May 1, 2011 | 02:52 PM
  #55
azmidget91's Avatar
being that your thick head isn't comprehending the point i am trying to get across, ill just leave this be
Old May 1, 2011 | 03:01 PM
  #56
Starting out, just getting the first few resistors in place:
And some more:
A few minutes later:
Install the 555IC and power up my 12vDC test station:
And the two output LEDs confirm sucess:
As soon as those LEDs get here we can begin the final process.
Old May 1, 2011 | 03:48 PM
  #57
coobies5's Avatar
this is badass, looking forward to the end results.
Old May 1, 2011 | 06:16 PM
  #58
jkilmurray's Avatar
As soon as your done with those, can you start a design for the 04-08's? I would definetly want some of those. Great work man.
Old May 1, 2011 | 08:13 PM
  #59
I would need a set of housings for prototyping and after that its a possibility to make copies and sell them as batch kits.
Originally Posted by Markus
If you're asking how many degrees up/down/left/right the parking lights should be clearly visible from, it's 45 degrees inwards, 80 degrees outwards, 15 degrees above horizontal, 15 degrees below horizontal. And identical angles for stop lights and turn signals too.
This is coming from an ex lead project designer from Philips, and hes quoting minimum requirements for housing designs. My lights comply with all of the above.
Old May 1, 2011 | 11:11 PM
  #60
foxhound81's Avatar
cant wait to see the end result
